Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GW11 not staying hot
Hello I have a GW11 Washer and in the last week I noticed that if I do a HOT wash, it does not fill in HOT, it fills in COLD water...Let me explain. I do an empty load to see what is happening. I put the wash on HOT and hit start. It first starts filling from the back with HOT water, for a little and then it switches to the side rinse (or whatever the side thing does). Then after about a couple minutes of the side rinse, the fill starts again in the back.....only this time all the water is COLD......what gives? So in other words it is giving me a COLD wash and not a HOT wash.....Can anyone help me? I have absolutely no codes show up in Diagnostics and I can turn hot or cold on in the testing of the machine, and that part works fine when you are in the diag mode. Any ideas that the PRO's can come up with will be very much appreciated......or has this one got everybody stumped? Thanks for your help in advance....
  • Jim D May 11, 2010
    try taking it off auto level
WHEN I CALLED FISHER AND PAYKEL PARTS CENTER WITH THE SAME PROBLEM . THIS IS THE REPY I RECEIVED. "THE HOT WATER FILLS IN FOR A SHORT TIME, THEN THE DIRVERTER RECIRCULATES FOR A FEW MORE MINUTES, THEN FILLS THE REMAINING WATER LEVEL YOU HAVE SELECTED WITH COLD WATER. THE REASON BEING: (GET THIS) FISHER PAYKEL SAYS THAT THE AMOUNT OF HOT WATER AT THE BEGINING OF THE
CYCLE IS SUFFICIENT TO DISOLVE THE DETERGENT. AFTER THE DEVERTER CYCLE (THE SIDE RINSE AS YOU CALLED IT) THE REMAINING WILL BE COLD WATER FILL".
HE ALSO STATED MANY PEOPLE CALL HIM ON THIS AND HE SAID IN THE MANUAL IT IS EXPLAINED THAT THIS IS THE WAY THE MACHINE WORKS. SO MUCH FOR ECOSMART
Posted on Jan 29, 2011
Why does the fisher and paykel washer gw11 drip water after cyle is finished?
If it drips inside than check and replace fill valve.
If it drips onto the floor check for a leak
Jun 05, 2014 | Fisher and Paykel Washing Machines
Connecting motor controller in gw11 washer
There is raised print below the socket with the name for the plug that goes in that socket.
Feb 15, 2014 | Fisher and Paykel Washing Machines
Looking for a water fill sensor for a fisher paykel gw11 The machine starts the cycle just fine, but when starts to fill, the water just trickles out and both water lines are open, whats wrong?
(sorry if this does not fully answer your question!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
My washer no longer produces cold water, only hot, except for the start of the cycle. The machine will tell me that it's not getting cold water. It doesn't matter whether I set the water temperature at...
It sounds like the fill hoses are inverted. Most of the Fisher washers only fill with cold water after the initial fill. So if the hose are inverted then it will only fill with hot. Beyond this I'm at a loss. Good luck
Apr 23, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
When going to wash with my GW11 it stops during the was cycle and the cold and hot water light blink and the machine beeps
Hi just read your posting.Now, when the hot and cold lights flash at the same time it means that you are not getting enough or no hot or cold water.Remove the cold and hot inlet hoses from the machine end and put the ends into a bucket.Now turn the taps on to see if you have water coming out the hot and cold hose and if the water pressure is adequate.Try a cold fill on the wash cycle and see how it goes.please reply and let me know if there is water coming out of the hoses at a good pressure and also what water temp do you select on the wash cycle.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
300 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
