Need to replace door boot there is a tension spring and wire clamp where do they go
  • Washing Mach... Master
  • 3,463 Answers
The spring goes on the inside of the door seal where it fastens onto the drum, u need to double the seal back in on itself to fit it , and the wire clamp fits on the out side of the seal where it is fastened to the front cabinet opening.
Hope this helps u.
Plz rate my solution.
Thanks.
Posted on Jan 02, 2009
HOW TO OPEN HARRIS GARAGE DOOR WHEN SPRING SNAPS
In such a situation replace the spring assembly and shaft that it is attached to. Then determine how many winds you need to add to the windlass for spring tension to get the door to lift. Depending how the door track it is set up the outer wheels that take up the lift cable spool about 16 to 18 inches of cable per revolution. The spring gets tensioned by sticking a length of half inch/13 mm rod into 1 of the 4 tensioning holes of the windlass that are cast into the clamping end of the spring and turning tension onto the spring by way of that windlass to lift the door once the cables are attached to the door and then clamped into the wheels, once the approximately correct lift height has been cranked into the spring.One rod would need to be left in place to hold windlass firm until the set screw is tightened. Then you can put on a hard hat, unlock the door and lift slightly- the rod will fall out if you wound the spring the correct direction.and the door should rise again with ease.
Dec 31, 2011 | Home Security
Tip
Replacing the Door Bellow On Whirlpool Duet Front Loader
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Feb 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Replacing the Door Bellow on Kenmore Elite Front Loaders
on Feb 07, 2008 | Kenmore Elite 45986 Front Load Washer
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
My front loader leaks water because the door gasket, called a boot I believe, is torn and needs replacing. There is nothing in the manual that gives even a clue as to how to remove this boot or how to...
There should be a spring loaded clamp on the outer panel and a screwed together wire clamp on the tub. You may have a water inlet clamp on this model and possibly a drain clamp at the bottom center. Take your time so you do not tear the new one. If you are really a go getter you can remove the top panel of the machine, the control panel, the door lock, the bottom panel and the entire front of the machine to gain easy access to the tub side of the boot. Remove the outer spring loaded clamp first before attempting to remove the front panel.
Sep 18, 2010 | General Electric WBVH5200J Front Load...
Door bellow needs replaced
Follow these steps: 1. Unplug the washer. 2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off. 3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way. 4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place. 5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer. 6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken. 7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free. 8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside. 9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser. 10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break. 11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube. 12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove. 13. Once the door boot is back in place, re-install the operator console and washer top. 14. At the operator console, place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks. There is a tech sheet inside the washer along one of the cabinet walls that explains this procedure. I hope you find these instructions helpful, let me know if you have any questions.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door Seal
not too bad a job
turn off mains. undo clamp that holds door boot to cabinet and peel off the boot.
the seal is then held onto the tub either by a large circular spring or maybe a clamp with a screw.
if it is a spring, then just force the boot downwards and pull outwards and the boot will come off.
if it is a clamp, undo the clamp and pull the boot off.
look at the new boot and you will see a groove that slips onto the lip of the tub. lubricate this groove liberally with washing up fluid or similiar.
start at the top and push the groove onto the lip. work in both directions round the boot forcing the groove onto the lip until entirely in position.
if a clamp was fitted, just put the clamp in the outer groove and tighten
if it is a spring, this is more difficult and you will find an extra pair of hands helpfull. stretch the spring and push into position in the outer groove.
fit the boot to the cabinet and replace the clamp
test for leaks on rinse cycle as water level is higher. there will be some foam from the washing up fluid.
remember to make a note of which way up the door boot was fitted as there is a top and bottom
Sep 04, 2008 | AEG L12700ViT Front Load Washer / Dryer
Torn seal on Duet
If you are talking about the door boot, follow these instructions:
I hope you find these instructions helpful and good luck to you. Let me know if you need further assistance.
Apr 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE washer
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow costs about $75-80 and is not too difficult to replace. Hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. Just follow these steps:
Post back if you have any questions.
Feb 26, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
