Roper Washer model RAX4232KQ0 won't fill with water
I replaced the lid switch because it was broke and that fixed the problem of not spinning. That seemed to create a new problem though. I put the machine back together and now it won't fill with water. I hear the timer working but nothing happens. I noticed that after I connected the two molex type connectors (one to the timer and one to the lid switch), there was one connector still unmated. The wires from that connector are pink, purple and tan. They are bundled up with the wires that are coming from the timer. Being a novice, I didn't think to look where that connector might have been connected too (if it was even connected to something), but I still don't see it's mate anywhere. Ground is connected also.
Please help, I'm at my wits end, thank you.
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Washer not spinning properly
This should be belt driven? I would imagine jut adjusting the tensionwould work.
Dec 02, 2013 | Roper RAS8445KQ Top Load Washer
I have a Roper ras7133kq1, top load washer. About 3 months ago I replaced the lid switch because it wouldn't drain or spin. Now it will ONLY spin, it won't fill with water or agitate, the only way...
If it won't fill you will need to replace the "water inlet valve" on the back of the unit. The unit will only agitate if it gets the signal from the water level pressure switch.
Here is the valve to order.
Nov 22, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Roper washer
That could be your lid switch. You should hear an audible click when you shut the lid. If the washer act like it is trying but won't spin that could be the drive coupler. I have a page which includes a service manual HERE
Sep 24, 2012 | Roper RAX4232KQ Top Load Washer
Roper washer agitator won't spin after kids loaded
It sounds like a someone has broke the lid switch to the washer. Below I have attached a picture, Item number 9 would be the part you seek. P# 3949247 Under the control panel you will find a harness that contains 3 wires coming out of the cabinet housing. The colors should be tan, white and green. If you jump the white and tan you unit should run and think the lid switch is working. Safety way is to unplug the unit to by-pass the switch and plug it back in and select spin only. This is only to test, you need a lid switch for safety. You should replace it ASAP if this test works for you.
Jul 26, 2011 | Roper RAX4232KQ Top Load Washer
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
Regarding a Roper top-loading washer, model #RAX4232KQ0: the interlock mechanism that controls power cutoff during the spin cycle only seems to be broken/defective. It interacts with the lid of the...
The part you are talking about is called the lid switch. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions do apply. The part number is 3949247 and can be found at appliancepartspros.com for about $23.
If you have questions, or require additional assistance please let me know. I hope you find this information helpful.
Aug 14, 2009 | Washing Machines
My washer won't fill up with water
SOUNDS LIKE YOUR INLET WATER VALVE HAS CHUCKED IN THE TOWEL.
WHEN YOU TURN THE MACHINE ON TO FILL UP THE VALVE OPENS TO LET THE WATER INTO THE MACHINE, IF THE VALVE DOES NOT OPEN THEN NO WATER WILL ENTER IT
THE VALVE WILL BE BEHIND THE PANEL WHERE THE HOSE ENTERS THE MACHINE
THEY ARE REASONABLY CHEAP AND SHOULD BE ABLE TO BE REPLACED BY A HANDYMAN OR WOMAN, JUST MAKE SURE YOU PUT THE WIRES BACK ON THE SAME TERMINALS AS THE OLD VALVE
Jun 06, 2009 | Roper RAS6233KQ Top Load Washer
I have a Roper brand top loader washer and it fills up but it won't drain or spin.
If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
Jan 30, 2009 | Roper RAK2751WWH Top Load Washer
I have a Roper Washer Topload (model RAX4232KQ0) and recently replaced the lid switch because it was broke. That fixed my problem but created another one though. I put the machine back together and now it...
good day to you sir from fixya,those colors go to the water level switch.the switch may have the color marks on it,or you can look at the wiring diagramthanks for using fixya.God bless your house,tom
Jan 02, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
