Question about Coby DVD-209
Disk rotating and a message "invalid disk"
I have coby dvd 283 player , i don't know why it is not playing ..........when i start the power button and insert disk , then on my tv on right hand upper side of the tv only a picture of the disk rotating round is seen .................pls help me out what shall i do When I insert a disk, the "spinning disk" (disk reading) icon comes up in the upper right hand corner of the TV screen, and stays there for a long time. Sometimes the disk actually starts for a bit, but then freezes (this may actually repeat several times), and eventually, the screen always goes black and comes up with "Invalid Disk." I'm using a DVD that I know played before on this player, and still plays on all of my other players, so it's not the disk format or a problem with the disk itself -- something has gone wrong with the player.
  • cepchopin Feb 05, 2009
    Unfortunately, this "solution" reminds me of the punchline of an old joke. A hot-air balloonist is lost in the fog near Seattle, and he floats up to a large building. He writes on a piece of paper and holds it up to the window, "Where am I?" Someone in the building writes back, "You're in a hot air balloon!" The balloonist writes back, "Thanks, I must be outside the Microsoft building, and you must work for MS customer support, because your solution was TECHNICALLY CORRECT, BUT UTTERLY USELESS."
    Do your players have some sort of time-bomb that sabotages them after 90 days? It's a freekin' paperweight now, mate!
    President:
  • 563 Answers
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: problem of COBY DVD 283 player
return it for a different one
Posted on Jul 01, 2008
jazzyboy11
  • 728 Answers
SOURCE: disk rotating and a message "invalid disk"
Try to use a different dvd because that one might not have been burned or made in the right format. If that doesn't work, then try blowing on the laser just in case there is dust on the lens causing it not to read the dvd properly. If that doesn't work, then you might need a new dvd player.
Posted on Oct 23, 2008
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
My coby portable dvd player keeps telling me that I have invalid
Thanks for using FixYa.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call the number above for instructions on getting the unit exchanged.
Dec 01, 2008 | Coby TFDVD5000 Portable DVD Player
Oct 23, 2008 | Coby DVD-283 DVD Player
Problem of COBY DVD 283 player
Jul 01, 2008 | Coby DVD-283 DVD Player
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
REGION CODE
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region code number 0
6. Press the “Setup” button to exit.
DVD283
1) Open DVD Tray
2) Press STOP
3) Press 70 plus region code 0 Example 700. Region
5) Wait five (5) seconds; the unit will automatically exit the region code menu.
Nov 02, 2007 | Coby DVD-283 DVD Player
Coby dvd player
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
Oct 19, 2007 | Coby DVD-207 Portable DVD Player
Not playing DVD
i have coby dvd 283 player , its new but i don't know why it is nt playing ..........when i start the power button and insert disk , then on my tv on right hand upper side of the tv only a picture of the disk rotating round is seen .................pls help me out what shall i do
Aug 23, 2007 | Coby DVD-283 DVD Player
DVD starts to load but does not play.
Not sure if anyone found this solution, worked for me.
1. Press SETUP
2. Press FFW, F REW, NEXT, PREVIOUS
3. Change the code to 255 using the RIGHT arrow key
This will unlock the DVD player for all regions.
Jan 26, 2007 | Coby TFDVD5000 Portable DVD Player
Coby DVD-209 Logo
202 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
