Question about Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale
ERROR message I just changed the battery in my model 7507 Taylor scales. I get 0s across then ERROR message
  • bokakagirl Jan 03, 2009
    i have the same problem as the one before me i have changed the battery and it still says error
  • Anonymous Mar 16, 2014
    Taylor model 7334 scale
  • 74 Answers
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    The taylor lithium electronic scale says 00 and then ERR. there is no ERR2. should i change the batteries? it never said lo.
    If you get an "Err" or "Error" message, you will need to step off of the scale, wait a few seconds and then step back onto the scale.
    Aug 10, 2010 | Taylor & Digital Scale Lithium Scale
    Changed the lithium battery 6 weeks ago it was
    Remove the batteries and clean both ends of the batteries with a pencil eraser. Do the same with the contact points in the scale. This should help. Bathrooms are damp, you may want to set it elswhere for reliable use.
    Jun 06, 2010 | Taylor Chrome & Glass Lithium Digital...
    I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
    From the Taylor Site http://www.taylorusa.com/faq-scales
    Here are the basic ERR messages and their meanings:
    • Error 0: Initialization
    • Error 1: Instability (scale is on an uneven surface ex: carpet)
    • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
    • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
    • Error 4: Body fat is out of range
    • Error 5: Water is out of range
    I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
    1. Remove the battery from the scale.
    2. Sit the scale on a hard surface floor.
    3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
    4. Re-install your battery.
    5. Place the scale back on a hard surface floor.
    6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
    7. Wait for the scale to turn off again.
    8. Step up onto the scale for a weight.
    If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
    Jan 15, 2010 | Health & Beauty
    How to calibrate a taylor scale 5571
    The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
    If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
    Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
    Err 1 message on Taylor Lithium Elec Scale model 7346
    This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
    Thank you for your e-mail. The reboot below may clear the error from
    your scale. You may need to do this several times to completely reboot
    the system. Please let us know if you have any questions or continue to
    display the Error.
    2. Set the scale on the floor without the battery in place.
    3. Stand on the scale for 10 seconds (still without the battery)
    4. Carefully replace the battery without turning the scale on.
    5. Using only one foot, tap the scale or apply just enough pressure to
    turn on the display. (It should show dashes or zero's) IMMEDIATELY
    REMOVE YOUR FOOT.
    6. Let the scale turn off
    7. Step on the scale for a weight reading
    Regards,
    Linda DLT
    Consumer Relations
    Taylor Precision Products
    & Salter Housewares
    2220 Entrada del Sol, Suite A
    Las Cruces, NM 88001
    Toll free - 800-289-0944
    866-843-3905
    Direct - 575-526-0944 ext 3172
    Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
    Taylor Lithium Scale Model 7000
    This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
    Oct 29, 2008 | Taylor Chrome & Glass Lithium Digital...
    Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale Logo
    1,251 people viewed this question
    Top Taylor Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
