Question about Hotpoint Dryers
Dyrer heats but tub does not turn
Dryer heats but tub does not turn
  • Hotpoint Master
  • 3,463 Answers
If the dryer is heating ,then it is going to be one of 2 things
  1. Drive belt worn or broken.
  2. Motor not starting due to a number of reasons.
  3. You need to remove the top cover to check the belt
Hope this helps with your prob.
Plz rate this suggestion.
Thanks.
Posted on Jan 02, 2009
Hoover dyrer 5030d not getting warm
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 03, 2011 | Hoover Dryers
Replaced belt tub turns but wont turn with load in it.Belt is 87/3/4-1/2 in length on model desf-l-2 dyrer
Sounds like you may need to adjust tension on the belt. To do that you have to expose the motor which will be in the back side of dryer and in the lower left or right hand side. Remove the access panel or on some models you have to remove entire back and then you will see the motor, there will probably be 2 bolts that need to be loosened on motor then you will need a small pry bar to apply tension on motor to tighten belt. Retighten bolts and put back cover on.
Feb 22, 2011 | Dryers
Electric dyrer not heating and theres no breaker switch on dryer only in garage
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 06, 2011 | KitchenAid KEYS750LQ Electric Dryer
Dyrer runs without clothes in it, but once you add the clothes it shuts off.
the motor has been hot and needs to be replaced if it runs with no cloths but wont run with a load or does the motor run but the tub not turn if this is the case you may just need a belt
Jan 06, 2011 | Kenmore Dryers
I have a Maytag Neptune gas dryer (MDG5500). The dryer overall seems to be working fine, but there is NO heat (Just a very recent problem). I have removed the front access panel but I am unsure exactly...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 06, 2010 | Dryers
No heat
If you have a gas dryer then here is a tip that I wrote about that problem...
If you have an electric dryer, check out thet tip for electric dryers at the bottom of the gas dryer tip...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 28, 2010 | Samsung Dryers
Dyer no movement/heat on stack unit- washer fine
It sounds like the dryer motor please change thanks
rate me
Apr 20, 2009 | Dryers
Maytag dyrer mdg6200aww the heating systwm does not stay on
Remove the vent from the rear of the dryer.
With no clothes in the dryer and the dryer set for hi heat run the dryer several minutes.
With a accurate thermometer check the exhaust vent temperature.
It should be 135 to 160 degrees.
If it is, you are OK. Just need to clean your vent and connecting tubing.
If not, replace your gas valve coils.
Mar 04, 2009 | Dryers
Dryers Logo
65 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
