Question about Acer Aspire 5100 Notebook
When i turn aspirezg5 nothing happends battary is charged
The power light is on the orange light does not come on at all i do not have a back up reboot cd what can i do? please help new to computers this was only brought 4 weeks ago
Emachines 250-1162 will not boot at all
I would say the battery has gone bye-bye. Some laptops won't even boot without a good battery.
Oct 03, 2014 | Computers & Internet
Emachines e350 wont turn on
sounds like your power supply is fried or the power port
Jan 19, 2014 | Computers & Internet
How to replace the alternator on 2005 Getz 1.3
Before you replace the alternator keep in mind the charging system is most likely controlled by the powertrain control module and this may cause a no charge condition. I suggest you have the charging system checked by a dealer before you replace the part. Or just throw one on and hope for the best?? No I do not recommend this.
Sep 27, 2012 | 2005 Hyundai Getz 1.3
Sir, my laptop CompaqEvo610C can not charging i check my battary on other same model of Compaq it is working and good condition and give backup more then 1hour. when i put the battary in my laptop again...
Since you tried your battery on another pc, then try a different charge power supply on yours. You may have a bad power supply adapter or your battery terminals on your pc may be dirty and need to be cleaned with rubbing alcohol and a cotton swab.
Sep 29, 2010 | HP Compaq Evo n610c Notebook
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
2002 cougar. Turn key nothing not a sound.
sound like alternator quit charging the battery.check battery should be 12.5 volts.if not charge the battery.remove and have alternator tested at auto zone or advance auto parts.dont forget to turn off radio when disconnect negative battery cable.
Aug 09, 2009 | 2002 Mercury Cougar
My charge light constantly flashes orange and my C600 won't turn on at all. I hold the power button and all the lights turn off. I got nothing. Just a blankscreen.
When you say charge light, was that the battery led light that you were referring to or the power button?
If it is the battery led light, try this:
Try to power on your laptop without the battery in your laptop.
take out the battery and just use the ac adapter, if it works fine then there could be a problem with your battery.
If is the power button that is flashing orange, then try to power cycle laptop.
turn off laptop.
take out the battery and the ac adapter.
then while those are out, you hold down power button for atleast 10-15 seconds.
put back the power source and check the led again.
Apr 08, 2009 | Dell Latitude D600 Notebook
Re: mobile
take the phone to a mobile servioce center and have them try to service the phone for you.
Apr 05, 2008 | Sony Ericsson K750i Cellular Phone
DS light will not turn on
well charge fur about a week it happend to me and this worked
Oct 01, 2007 | Nintendo DS Lite Console
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
