I have a Roper Washer Topload (model RAX4232KQ0) and recently replaced the lid switch because it was broke. That fixed my problem but created another one though. I put the machine back together and now it won't fill with water. I hear the timer working but nothing happens. I noticed that after I connected the two molex type connectors (one to the timer and one to the lid switch), there was one connector still unmated. The wires from that connector are pink, purple and tan. They are bundled up with the wires that are coming from the timer. Being a novice, I didn't think to look where that connector might have been connected too (if it was even connected to something), but I still don't see it's mate anywhere. Ground is connected also. Please help, I'm at my wits end, thank you.
  • blburson Jan 02, 2009
    Hey Tom,
    I greatly appreciate the information. My washer however doesn't have any electrical wiring that goes to the level switch. The only thing that connected to the switch is a 1/4" clear plastic tubing that runs to the tank. The water filled up fine before I replaced the lid switch, now I'm stuck. And that connector that doesn't have a mate is puzzling me also; I still can't find where that things connects.
    Sergeant:
  • 311 Answers
Good day to you sir from fixya,those colors go to the water level switch.the switch may have the color marks on it,or you can look at the wiring diagramthanks for using fixya.God bless your house,tom
Posted on Jan 02, 2009
  • Thomas Malailua
    Thomas Malailua Jan 02, 2009
    yes that conector dose go to your switch with the clear tube.im sure as my name is tom.take your time you can get it hooked back up
  • Thomas Malailua
    Thomas Malailua Jan 03, 2009
    how its going with that wiring repair.hopefully your washing clothes by now.please dont forget our ratings.glad i could help tom
Washer not spinning properly
This should be belt driven? I would imagine jut adjusting the tensionwould work.
Dec 02, 2013 | Roper RAS8445KQ Top Load Washer
Tip
How to fix your washer if it does not drain or spin
kenmore whirlpool,roper,kitchenaid,estate,inglis washer if it will not drain or spin,it's a bad lid switch,remove the 2 head screws,flip the top up,pop the 2 spring clip,unplug the lid switch,pull the cabinet off,remove the 2 screws under the lid,replace switch,put everything back together and your done,most times the model number is under the washer lid-mike
on Jan 31, 2010 | Washing Machines
Roper washer agitator won't spin after kids loaded
It sounds like a someone has broke the lid switch to the washer. Below I have attached a picture, Item number 9 would be the part you seek. P# 3949247 Under the control panel you will find a harness that contains 3 wires coming out of the cabinet housing. The colors should be tan, white and green. If you jump the white and tan you unit should run and think the lid switch is working. Safety way is to unplug the unit to by-pass the switch and plug it back in and select spin only. This is only to test, you need a lid switch for safety. You should replace it ASAP if this test works for you.
Jul 26, 2011 | Roper RAX4232KQ Top Load Washer
Lid switch not working
Hello, welcome to FixYa.
Based on your description it sounds like you`ll need to replace it, but first...
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis topload washer, not neccessarily applicable to ALL...especially those built in the past 1-2yrs. the model number would distinguish if it applies to your particular model )
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
good luck.
macmarkus :)
Aug 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills but does not advance to wash cycle without repeatedly opening and closing the lid.
Based on your description it sounds like a lid switch problem.
good luck.
macmarkus :)
Aug 23, 2010 | Whirlpool Washing Machines
Washer fills with water but won't agitate or spin.
good luck.
macmarkus :)
Aug 19, 2010 | Estate Washing Machines
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
Regarding a Roper top-loading washer, model #RAX4232KQ0: the interlock mechanism that controls power cutoff during the spin cycle only seems to be broken/defective. It interacts with the lid of the...
The part you are talking about is called the lid switch. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions do apply. The part number is 3949247 and can be found at appliancepartspros.com for about $23.
If you have questions, or require additional assistance please let me know. I hope you find this information helpful.
Aug 14, 2009 | Washing Machines
How do I replace the lid switch on my waher it's a Roper
buy a replacement switch and the top lifts off from the front.  It could be the switch has only come loose or the probe on the lid has broken off.
Feb 27, 2009 | Roper RAX4233PQ Top Load Washer
I have a roper washer model#RAS8445JQ0 it washes but won't spin,could it be a relay or timer ?
most likely lid switch try pressing down with pencil if switch not completely broke.. if it works replace switch
Sep 06, 2008 | Roper Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
