Question about Sony PFM-42V1 42 in. HD-Ready Plasma Television
Sony PFM-42V1 42 in
Left 1/3 of screen has "white noise box". I can power up the tv, but that left 1/3 has a box that has no picture. It's just white with a couple of vertical lines, sometimes the line turn red/blue/green. The box just appeared one day. I have been using it for 2 years, had it hung up on wall, and on with a display that changed continuously. Never saw any symptoms or anything that looked like it was going out. I have not tried to troublshoot or called a repair place. I know the warranty is expired. I am a PC Tech so I am sure I could replace a part if needed. I just need to know where to start. Troubleshooting is hard to find on the net. Please help!
    Scholar:
  • 77 Answers
Sounds like X buffer/scan or control/logic problems. without good service info you will have a hard time troubleshooting. And it will get expensive guessing. Could even be a panel, probably gonna need a pro look.
Posted on May 11, 2007
Sound dropouts when the tv screen is mostly white.
need to know brand and model to help and also if a box is being used for signal or not- a box can cause this.
Nov 28, 2012 | Televison & Video
Picture is frozen onto the screen. Tried powering off tv and cable box that did not work. Next unplugged TV and that did not work
Sounds like a burn in, this is common when some still image is left on the tv screen for sometime, the only hope is to get to a white screen or static screen and let set for awhile, like the old days when you didn't have cable or any input and the tv just frowns.
Jan 23, 2011 | Vizio VW32L 32 in. LCD HDTV
My Philips Plamsa won't turn on, has a black screen but the power light is on. There is also a constant clicking noise. Any ideas of what this might be. The tv is a couple of years old.
The picture is White or Black:
1. Adjust picture setting such as brightness or contrast
2. Check the color settings
3. Check to ensure you cable connections are connected properly.
Jan 20, 2011 | Philips 42PFP5332D 42 in. Plasma...
TV made a buzzing noise then turned off. Now power light flashes
You have a very Technical problem with this TV. you may have 2 big problems, ballast and dmd. but it could be something else. If you decide to repair it, honestly you will spend more than 300dlls on it, if you like to, go to fixyourdlp.com
Sep 03, 2009 | Samsung Televison & Video
Green and purple vertical lines on TV - no picture
Do you have a Motorola HD Digital Cable Terminal? And does this issue only happen on NON-HD Channels?
If so, it could be the digital box settings caused by a firmware upgrade by your provider.
If this is the case do this
  1. Go up to the front of the cable terminal
  2. find the menu and power buttons on the left hand side
  3. Make sure both your TV and Cable terminal are ON
  4. Turn off the digital cable terminal wait 1 second then press menu
  5. You should get a white screen
  6. One options should be "4:3 Override"
  7. Set it to OFF
  8. Press Power to turn off the digital box then power it back on
Hope this helps
Aug 21, 2009 | Sony Televison & Video
HDMI not always working
with the tv on, walk up to the cable box and turn it off. using the cable box remote quickly press the red menu key. you should see a white screen with setup information on the screen. the first setting is tv size,that should be 16 x 9. the second should be set to 1080i. and the 4:3 override to 480p. you can change these setting using the up and down arrow keys to select and the left and right to adjust the settings. don't panic if you loose the picture for a moment, it will come back. when you are done, press the menu key again quickly. then turn the cable box on using the power button at the front of the cable box.
Jan 11, 2009 | Sony BRAVIA KDL-46W3000 Television
Magnavox Projection Picture Problem
Sounds like you may need the convergence amps changed and also resistors in that area and maybe fuses.
Jan 02, 2008 | Philips 9P5034C 50" Rear Projection...
Lines on screen
Can you take a picture of the screen and post it? It is not possible for both the horizontal and vertical stages to fail at the same time to produce a cross. A picture of the screen would help significantly.
Aug 08, 2007 | Daewoo DTQ-25S2FC 25" TV
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
Sony PFM-42V1 42 in. HD-Ready Plasma Television Logo
129 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
