Question about Pyle Pl3156rd Led Break Lights
The break lights of Santro is glowing continuously
We banged the car in a wall and applied the brakes. After that the break lights are glowing continuously.
    Problem Solver:
  • 12 Answers
You got a short in your wiring harness it may be cut due to the impact
Posted on Jan 02, 2009
What when coming to a full stop and applying the clutch and the break sometimes causes a thumping sound or stuttering sound. At times when releasing the break and the clutch th
You should only put the car in neutral then apply the brake.
If you continue to drive with the brake and the clutch it's going to burn out the clutch.
Just when you are coming up to a light take the shifter out of gear and then put it in neutral then apply the brakes.
You will notice the car will drive better
Hope this helps.
The stuttering and jerking motion means usually that you are starting at a to high of a gear or to low. The brake will cause the situation you are having. if you are applying it any time during shifting
Apr 17, 2015 | 2001 Toyota Tacoma Idle Speed Regulator 01...
How do I check brake switch wiring
those switches make continuity ( makes the circuit to the brake light ) when we brake our vehicle, then when brake pedal is not being pushed it disengages the circuit, therefore turning off break lights.
Use an ohmeter with no voltage applied to ciruit , check switch With switch engaged ( zero or about zero ohms ), switch disengaged should show infinity ( nothing on the ohmeter ).
Sep 22, 2014 | 2001 Chevrolet Lumina
My signal lights in my dash both light up when i apply the breaks and only works when i let go of the breaks
Usually this is a short in one of the sockets that holds the bulb, your brake lights are back feeding power causing your turn indicators to glow on dash when you hit the brakes and will stop the turn signal from flashing when you step on the brake pedal also. Start with sockets on rear and look for any shorted or blackened socket ends.
Jan 20, 2014 | 2000 Toyota Avalon
When applying break hearing a banging noise and break pedal fluxuates up and down.
Suspect a faulty rotor or drum. Make sure brake calipers are not sticking.
Nov 25, 2013 | 1988 Ford F 150
Brake system
You have a leaking brake line or Caliper. You need to fix the hole by replacing parts.
Jun 19, 2013 | 1996 Mercury Mystique
Rear tail light won't light up
You might have a bad wire. If it was both tail lights, could be your tail lamp fuse or brake switch.
Feb 05, 2011 | 1998 Lincoln Mark VIII
Why does the parking break light stay on in my 97 Olds Cutlas Supreme. I have checked the level of the break fluid and it is full. I did have new break lines put in last year. I did have to slam on my...
Apply the parking brake with the vehicle parked, engine turned off and transmission in Park. Release the parking brake completely, then apply it again, and ensure that it is fully released. Turn the ignition on, check to see if the Parking brake warning light is on. If it is NOT on, apply the parking brake and check to see if the warning light comes on. If the light come ON wihen the Parking brake is applied,.....fully release the parking brake and check if the warning light goes OFF. If it does NOT go off, then an adjustment is needed at the parking brake switch.
Jan 09, 2011 | 1992 Oldsmobile Cutlass Supreme
When brake is applied a beeping noise is made, brake fluid is full, the other thing is that when it beeps the right hand indicator light glows, and stays on until break is released
Sounds like u have a set of crossed wires.most likely your brake lights and your indicator lights. as for the beeping. could be another short ti power for your door dinger. this is assuming that the beeping is the same as if u left your keys in the ignition
Oct 23, 2010 | 1994 Toyota Corolla
Glow plug light flashing on VW Sharan
i dont think it will hurt it, you might just be dealing with a loose wire
Dec 21, 2009 | 2001 Volkswagen Jetta TDI
While heavily applying the brakes at high speed the truck shakes.
If the front of the truck is doing all the shaking then the front brakes are doing all the stoppong. You need to check the rear brakes and change if neccessary. If they do not need to be changed then you should adjust them accordingly. I hope this helps. Don.t forget to rate my answer, thanks.
Feb 26, 2009 | 2002 Toyota Tacoma
Pyle Pl3156rd Led Break Lights Logo
78 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
