Question about RCA RTD255 System
IPOD does not work in USB
We have the RTD215 for our daughter and the USB port says "loading" but then displays "No File". It states on the box that it is iPOD ready. Need help before I look even more stupid in front of my daughter please.I have similar problem. I have RTD215 also. My Sansa Express will not work in the USB Port. I was careful to make sure the Express was in MSC/USB mode. When I plug it in, the Sansa says "reading", reading reading, but gets stuck there, and locks up the system, till the batteries run down, and I have to charge and reload it. I tried doing it with both the adapter cable which came with the Sansa, and by plugging the Sansa Express directly into the USB port. The message on the monitor receiving the RTD215 input variously returns messages "Loading..." and "No USB detected." If anyone has any ideas on fix or work around, much appreciated.
  • 2 more comments
  • Cd123456789 Jan 11, 2009
    The purported solution was completely non-responsive. We are not talking about computer system compatibility. We are talking about compatibility between the RCA DVD/CD player's USB port and the MP3 player. All devises involved have been specifically described.
    Again, the new posted solution is nonresponsive, and generic at best. We are talking about a home entertainment unit (RCA), which has a built in USB drive with no ability to download to as far as i am aware. I thought USB ports were supposed to be pretty generic things. You are not addressing the specific components involved, which have been identified.
    Sorry, but somehow my query, got tagged with the query from the lady with the iPOD, tho we had similar problems - inaiblity of the RCA unit to read the MP3 players. My MP3 players are specifically identified - eg. Sansa Express
    machadojr_fe
    I am not sure about your proposed hard reset solution. If you are addressing the lady with the iPOD, fine. But I have the Sansa, for which your hard reset instructions are off. I have essentailly done a hard reset on the Sansa, taking everything off, clearning/scrubbing, reformating, etc., and the problem remained the same.
    President:
  • 846 Answers
On the remote is a USB button to switch it to USB mode when you are ready to use it, are you pushing this ?
Insert the USB drive's connector into the main
unit’s USB jack of the unit. To disconnect, unplug
the drive.
USB device playback features
1. Press USB to select USB mode.
2. Playback starts automatically. Press PAUSE to
pause playback and press PLAY again to
resume.
3. Press STOP to end playback.
4. Press CH+/- buttons on the remote control to
skip to the previous or next file.
5. You may also follow the playback instruction
steps 3-7 on playing mp3/WMA files and jpeg
files on P.14.
Posted on Jan 11, 2009
  • 10,515 Answers
Update the firmware......
Follow the diagnostics :)
1. I assume you are using a USB Port to connect the device?
--Yes - Continue - If No, please specify connection method
2. Does using another USB Port on the PC make any difference?
--No - Continue - If Yes, that port on the PC is not functioning.
3. Are other USB devices that you plug into the PC detected?
--Yes - Continue - If No - the USB system on the PC is not functioning - upgrading or reinstalling the driver might work if it is not a hardware malfunction.
4. Did you install any type of driver for the Sandisk mp3 player?
--No- Continue - If Yes - uninstall and reinstall the driver.
5. Do you have another USB cable to try with the device?
-- If No, try another PC.
Thanks,
  • taran_2005
    taran_2005 Jan 11, 2009
    If u r using vista, u might face this error....
    In this case,
    *If the procedure below does not work then that's the time you delete the
    INFCACHE.1 (or it's backup), not restored. Deleting the INFCACHE.1
    immediately might give you this error message, "Destination folder access
    denied".
    1. Locate the file INFCACHE.1 in C:\Windows\inf
    2. Right click on the INFCACHE.1 file, select Properties >Security >
    Edit, and give
    your account full control.
    3. Delete INFCACHE.1, or rename it to INFCACHE.1.BAK or temporarily move
    to your desktop.
    4. Reboot the computer....
    However, i hope u wld be able to recognize the error using mah first reply.
    Thanks.
  • 55 Answers
The RTD215 is IPOD ready, unfortunately this does not mean it comes with everything needed to connect your IPOD. To play from the IPOD to the stereo will require an optional IPOD dock. Using the USB connection, you would be able to rip CD's from the stereo to the IPOD, but this connection will not work to play from the IPOD to the stereo.
The terminology ready is really misleading, but technically accurate. It will play from an IPOD, just doesn't come with the necessary dock.
  • Randy Dix
    Randy Dix Jan 11, 2009
    This is the same issue with your Sansa. You should be able to burn CD's from the stereo to the Sansa, but this stereo is no Sansa compatible, there is no way to play from the Sansa to the stereo with this system.
    Sergeant:
  • 431 Answers
May i know u operating system
  • 916 Answers
Press Select button and Vol + at the same time. This will do a hard reset it should resolve the issue if not please post back the results and I will help you the best I can.
Posted on Jan 02, 2009
  • RCA Master
  • 19,396 Answers
Before plugging the ipod you need to install itunes.
Try unplugging the Ipod, then downloading and installing itunes again, before plugging in the ipod.
See
Apple - iTunes - Download iTunes
  • Ginko
    Ginko Jan 11, 2009
    Sometimes USB ports do not work well because of elecrosttic charges problem. To fisx that , cut the power to RCA DVD/CD unit for fifteen or twenty minutes.
    May look silly, but give it a try.
    President:
  • 1,990 Answers
Welcome to Fixya! Sounds like you need some Drivers. You will have to go to the Manufacturers Website and Download USB Drivers for this Model. Downloading I-Tunes for Windows would help you too. Let me know what happens!
    Master:
  • 413 Answers
If you are having problems with two different usb devices on the same computer it sounds like you need to update the drivers for the usb ports. We need to know what kind of computer you have and what operating system you are running on it.
Tip
How to View a JPG file on my iPod Touch
<p>You can sync your iPod Touch with iTunes software on your computer for music and videos to add to your device. However, you can see some photos on your computer in JPG file format, you may want to add to your iPod Touch and transport. Photos can also be added to an iPod Touch, albeit a little different than other files. Once synchronized from your computer to your device, you can view your JPG files on the screen of your iPod Touch. <br /> <p><br /> <p>1. Connect the larger end of the iPod's USB port at the bottom of your iPod Touch, and plug the other end into a USB port on your computer. The iTunes software is started automatically. <br /> <p><br /> <p>2. Click on your iPod Touch from the "Devices" on the left side of the window to the "iPod Summary" section displayed in the middle of the iTunes window. <br /> <p><br /> <p>3. Click on "Photos" at the top of the "iPod Summary" section. <br /> <p><br /> <p>4. Check the box to the left of "Sync photos." To select all photos in "Photos" folder to synchronize, select the "All Folders" option. If you just take some photos to sync, click on "My Pictures" in the drop-down menu, click "Choose Folder". Navigate to the folder containing the photos you want to sync and click "Select Folder". Click on "Selected folders" and check the box to the left of the folder you want to synchronize with the iPod Touch. <br /> <p><br /> <p>5. Click "Apply" at the bottom of the window, click "Sync". Disconnect the iPod Touch as iTunes does to do so. <br /> <p><br /> <p>6. Press the "Home" button at the bottom of the iPod Touch, and move the slider to unlock the screen. <br /> <p><br /> <p>7. Press the "Photos" at the bottom of the screen. <br /> <p><br /> <p>8. Browse through your photos and play the JPG file you want to see the thumbnail. <br />
on Jul 21, 2011 | Computers & Internet
Rca rtd215 hometheatre system wont connect to ipod
it will not read from an ipod and we had the same problem. We plugged in a regular usb to clear and then it went away. it will play music from a usb but not a ipod.
Dec 12, 2009 | RCA RTD215 Theater System
Usb connection for ipod
Do other devices work in the same USB ports? Does the iPod show up on a different computer? Have you tried different cables? Does it still charge?
Try that first. If not, you can do a reset by holding the top of the click wheel and the centre button. You can also try resetting it in menu.
Beyond that it sounds like warranty time.
Dec 26, 2008 | Apple iPod nano
I cannot restore my 5th generation 30 gig ipod
HI
Try this out
Disconnect and reconnect your iPod and then attempt to restore.
  • Restart your computer and then attempt to restore your iPod.
  • Disable or Enable Disk Use on your iPod and then attempt to restore.
  • Try connecting your iPod to a different USB port and then attempt to restore.
  • Remove any third-party USB devices you have connected to your computer (it is not necessary to remove your keyboard or mouse).
then try this out
  1. Disconnect the iPod from the computer and close iTunes.
  2. Highlight all of the following 10 lines of text that begin with regsvr32 and then choose Copy from the Edit menu of your web browser: regsvr32 /s softpub.dll
    regsvr32 /s wintrust.dll
    regsvr32 /s dssenh.dll
    regsvr32 /s rsaenh.dll
    regsvr32 /s gpkcsp.dll
    regsvr32 /s sccbase.dll
    regsvr32 /s slbcsp.dll
    regsvr32 /s mssip32.dll
    regsvr32 /s cryptdlg.dll
    regsvr32 /s initpki.dll
  3. Open the Notepad program by navigating to:
    Start > All Programs > Accessories > Notepad
  4. In Notepad, choose Paste from the Edit menu. Note: make sure that the text that appears in Notepad is the same as what is shown above.
  5. From the File menu, choose Save As.
  6. In the File name: field type appleipod.bat and save the file to the Desktop.
  7. Close Notepad and locate the appleipod.bat file. It should appear on the Desktop with the icon shown below: ts1539_1.jpg
  8. Double-click the file and you will see a black window appear on the screen for about a minute. Wait until the window automatically disappears and proceed to the next step.
  9. The appleipod.bat file can be deleted at this time.
  10. Open iTunes and connect the iPod.
  11. When the iPod appears in iTunes, restore the iPod and resync your content.
this should work fine
Aug 10, 2008 | Apple iPod MA446LL/A MP3 Player
Why does my iPod appears on my computer but not in iTunes?
Laptop or portable connecting via USB? "See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh with a Windows PC. To see which platform your iPod is formatted for, follow these instructions. Your iPod isn't connected to a high-power USB port If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer (not a low-power one such as the USB port on your keyboard or bus-powered USB hub). Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer (or to a self-powered USB 2.0 hub that's connected to a high-power USB 2.0 port on your computer) if the computer still doesn't recognize your iPod. Alternatively, if your computer has a FireWire connection, try using that instead. If you're connecting an iPod, iPod mini, or iPod shuffle to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. You're not using a WHQL-certified IEEE 1394 card If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod. If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this: Go to the Windows Hardware Compatibility List website. Enter All Products in the ""Search for"" field. From the Product Categories pop-up menu, choose 1394 Controller. Click the Search Now button. Note: Windows XP information is not listed on the initial search screen, but is listed when you click on an individual card. You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP. (Apple sells FireWire cards that are compatible with iPod at the Apple Store.) To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it. Your connections aren't secure Make sure that there i
Oct 02, 2005 | Apple iPod nano
Maybe radical but this worked for me.
My computer-select ipod,Right click and format disc (fat 32)
Once refomatted plug in to computer and start Itunes.
Click on Restore to factory settings, At the end of that you will need to plug it briefly into an ac outlet.
Reconnect ti computer and start Itunes.
Sync with library.
This worked for me after trying everything else I could fine failed.
My error when I ran diagnostics said "one or more sync tests failed."
Sep 28, 2005 | Apple iPod nano
For Mac users "iPod does not appear in iPod Updater or iTunes in Mac OS X Under some circumstances, iPod appears in the Finder in Mac OS X, but does not appear in the iTunes Source list or does not appear in the iPod Updater. Symptom iPod's disk icon appears in the Finder, but it does not appear in the iTunes Source list or in the iPod Updater. Note: The iPod may appear in iTunes, but not in the iPod Updater. Important: If you are using iPod shuffle, you must have 10.2.8 or 10.3.4 or later to connect it to your Mac over USB. Other iPods require 10.3.4 or later Products affected Mac OS X iPod (5 GB) iPod (10 GB) iPod (touch wheel) iPod (dock connector) iPod mini - USB requires Mac OS X 10.3.4 or later. iPod mini (Second Generation) - USB requires Mac OS X 10.3.4 or later. iPod (Click Wheel) - USB requires Mac OS X 10.3.4 or later. iPod with color display (including iPod photo) iPod nano Solution iPod nano Certain models of single processor Power Macintosh G5 computers may show iPod nano mounted in the Finder but not recognized in iTunes. If this happens to you, try restarting your computer and Setting Energy Saver to highest performance and turn off hard disk sleep. If you have an iPod nano, but don't have a G5, then follow the other steps below. Mac OS X 10.4.x Perform an archive installation of Mac OS X10.4. Mac OS X 10.3.x Navigate to /System/Library/Extensions. Drag the iPodDriver.kext file to the Trash (you will be required to enter an administrator account password). Download and install the Mac OS X Combined Update 10.3.9. Restart the computer when prompted to do so by the installer. Connect the iPod. Mac OS X 10.2.8 and earlier To resolve this issue with earlier versions of Mac OS X, you'll need to delete one file and reinstall iTunes. Follow each of the steps below. Step 1 Delete the file using Terminal Warning: The steps below describe how to remove a file by entering commands in the Terminal application (located in the Utilities folder inside of the Applications folder). Users unfamiliar with Terminal and UNIX-like environments should proceed with caution. The entry of incorrect commands may result in data loss or unusable system software. Open Terminal (/Applications/Utilities). Type: sudo rm -R /System/Library/Extensions/iPodDriver.kext Press Return. Enter the administrator account password when prompted. Quit Terminal. Restart the computer (From the Apple menu, choose Restart). Step 2 Reinstall iTunes Download the latest version of iTunes from the iTunes download page. Install iTunes. Restart the computer after the installation has completed. Connect iPod. Step 3 Delete the iPod.plist file Remove the following file in the your home directory and launch the iPod updater again ~/Library/Preferences/com.apple.ipod.plist "
Why my iPod doesn?t appear in iTunes?
RCA RTD255 System Logo
61 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
