Question about 2wire (1000-000057-000) Modem
Connect Wii via wireless router
I purchased a wireless router but until I bought a wii I had no use for it yet. Now that I have a wii I cant figure out how to make the wireless featue of the modem work.
  • troubleplaye Mar 01, 2009
    l cant get the wii to connect to the router what am l doing wrong?
The modems wireless feature is always on. For some reason entering the security code wasn't working so I turned off the security feature and it worked fine. After the wii downloaded updates I turned on the security to the most secure settings and everything continued to work. I guess maybe the wii update fixed the issue or I just needed to change to the most secure setting.
Posted on Jan 06, 2009
Can u have netflix on your wii without having wifi???
You don't need Wi-fi specifically, but you do need an internet connection. If you do not have a wireless router, you will need to purchase a Nintendo Wii LAN adapter. This allows you to connect the Wii to a wired router using an Ethernet cable.
Dec 19, 2013 | Nintendo Wii Console
Cant connect to my router netgear
http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    Nov 26, 2011 | NetGear WGR614 Wireless Router
    How do u get internet on your wii
    Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note you will need access to a wireless internet connection, or must have a wireless router in order to connect your Wii to the internet. The Wii only connects via wireless signal!
    http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
    Sep 04, 2011 | Nintendo Wii Console
    We are unable to connect our Wii to the internet. I believe it has something to do with the renewal of my AVG security, but I cannot figure out what it is. Can you help me?????
    It has nothing to do with your AVG antivirus as the Wii doesn't connect through you computer to the Internet, it connects to to the Internet via your wireless router (most common) or a wired router with a Wii LAN adapter (uncommon connection, adapter sold separately). Here is everything you need to know about connecting your Wii to the Internet.
    http://www.nintendo.com/consumer/systems/wii/en_na/online.jsp
    May 08, 2011 | Nintendo Wii Console
    Up until about a week ago, our wii was connecting to the internet with no problems. No when we try to connect it gives us and error code or asking if we would like to set up internet connection. I have...
    Your error code indicates that your Wii can't connect via wireless to your router. I would check to make sure your router is functioning properly and to restart it if required. I would then check to make sure that the configuration on your Wii matches that of your router. I would also check to see if any other devices can connect to your router, if so, then the wireless card on your Wii may have died and is something you will likely need serviced by Nintendo.
    Apr 01, 2011 | Nintendo Wii Console
    How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    Cant connect wii to internet
    The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
    For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
    nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
    i hope this helps
    Nov 05, 2009 | Nintendo Wii Console
    Bought wireless connection still cant connect to internet on wii system Belkin_G_Wireless_9430BF is the namw of the wireless connector can connectwith ps 3 but not wii
    does the wii see the router do you have a laptop to make sure its sending a signal try this dis connect everything plug in the modem let it symc up by it self then plug in the router and hook up the cat 5 cable to the router
    the try to sync the connection with the wii by searching for the router
    it helps to name your router first with a laptop but that should work if not let me know iam a cable tech with a few tricks
    Aug 01, 2009 | Nintendo Wii Console
    I cant connect my wii to the internet
    Try switching your wireless router to channel 1. Also... have you setup all the security in your Wii to match your router?
    Dec 28, 2008 | Nintendo Wii Console
    Im having a problem w/my wii
    Is it not getting an IP from the Router? Try resetting the router and see what that does...
    Mar 25, 2008 | NetGear WGR614 Wireless Router
    2wire (1000-000057-000) Modem Logo
    561 people viewed this question
    Top 2wire Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
