Need to open the case on an ACER 24" LCD Monitor
Acer 24 inch LCD monitor - Model B243W. I need to open this up to check the connections on the lamps/inverter board. This monitor lights up intermittently. I can't find any way to open this unit up!Any help?
New L C D monitor How to Work I Gave Connection Are Correct But Asking Select Proper Boot Device ??
Posted on Aug 28, 2010
  • 31 Answers
You are advised to take it in to an authorised technician for repair. Never open the case unless you are qualified and certified.
Posted on Nov 06, 2009
Screen has a blue hue...how do I correct his?
choose the menu button on your monitor move over to the picture option and it should display your color option in that menu a long with the hue as well
Sep 10, 2014 | Acer B243W 24 inch LCD Monitor
Acer disassembly
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure is given with illustrations and other details.
Jul 29, 2014 | Acer G235H 23 inch LCD Monitor
I have an acer b243w monitor. it powers on for about 2 seconds then goes black. thens it tries a second time and the same thing and making a slight hiss noise and the back of the monitor smells like static...
You may have high voltage arcing, bad inverter transformers, bad DC filter caps, bad lamp wires. You will have to open it up and inspect the inside first.
Failed ACER monitors: http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Bad lamps: http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 08, 2011 | Acer B243W 24 inch LCD Monitor
Monitor says no signal
You will need to check that the connection with the computer is firm and also the correct drivers are loaded on the computer.
You can get the driver from this site and install on the computer.
You will have to select the operating system of your computer.
Hope this helps.
Mar 22, 2011 | Acer V243H 24 inch LCD Monitor
Acer Monitor Lcd 22in B243w Monitor goes black and shuts off
try to turn on again the power button or in the remote then if did not work or power on.Your monitor have problem in power supply.need a technician for repair.If the power on then check the timer settings.
Oct 05, 2010 | Acer B243w 22" LCD Monitor
I have a Acer B243W 24" Monitor. There is a vertical neon green line (1x1200 px) on the screen and i have no idea what it is there for and how i can get rid of it. someone might help? thx!
It's there because the connection inside the LCD panel that commands that column is either busted or inactive - it's a hardware fault that cannot be fixed. If it's too much to bear then the entire monitor must be replaced.
Jun 22, 2010 | Acer B243w 22" LCD Monitor
I have tried all option on the Acer screen so the
The resolution is done at the PC video output setting, not at the monitor, you should set the PC video resolution to be at monitor native resolution: 1920 X 1200 @60Hz This will give the correct aspect ratio of your display.
Mar 26, 2010 | Acer X243W 24" TFT wide format screen 24...
Acer 22'' Graphics too small
Right-mouse-click on your "wallpaper".
Choose Properties.
Click Appearance.
Change to a larger font-size.
Nov 17, 2009 | Acer B243w 22" LCD Monitor
How to open acer lcd monitor model no AL1706A
gulabgoud, Most monitors come apart the same way, or almost!!! May I suggest that you visit YOUTUBE to search and view some video clips of VALID (good) "lcd monitor disassembly" and / or "lcd monitor repair" ??? Have you ever heard the expression "a picture (in your case video clip) is worth a thousand words" Good luck guy, your on your own!!! If this helps you out, please rate this response on fixya. But don't come back here CRYING or complaining IF YOU SCREW UP YOUR MONITOR !!! Bye for now.. 12fix louie
Nov 13, 2009 | Acer Computers & Internet
I can connect my new acer X203H LCD monitor to computer
Open your cpu cabinet.
Refix RAM memory .
Pull cmos cell from motherbord for 10 minutes.
Pull processor fan and processor then refix both clean dust from all parts.
Remove pci cards from pci slot then check.
Let me know if you need more assistance.
Thanks.
Oct 02, 2009 | Acer X203H bd Monitor
Computers & Internet Logo
487 people viewed this question
David Payne
David Payne
