Question about Asko 1375 Dishwasher
Need upper/lower racks for Asko 1375
Looking for replacement racks for Asko 1375
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
An authorized servicer could order them for you but I just priced them and they would cost over $300. You can find a servicer at asko's website.
Posted on Aug 06, 2009
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
My ASKO 1375 seems to wash fine but will not drain. We checked the pump, filters and drain hose. All seem to be fine. Suggestions?
It is easy to have insoluble items clog underneath the lower spinner. Take it off and clean the holes thoroughly. Check for bits of glass. If this is not the problem, it could be that the pump is broken.
Dec 30, 2010 | Asko 1375 Dishwasher
Upper basket keeps sliding forward as I load lower rack. Can you help me make an adjustment to prevent this annoyance. Thanks
Hello, Welcome to fixya. Based on the info you provided it's likely a pretty easy fix. The machine is leaning forward slightly and it shouldn't be. Remove the top screws fastening the machine to the counter...if applicable, some are on the side if granite counters or similar exist etc. Then take off the lower kickplate/access panel and screw the front leveling legs down ( which will cause the tilting of the machine back slightly ) and screw the back legs up, hence the rack should no longer slide out on it's own. macmarkus_77.jpg As shown above, these are locking nuts for the legs so make sure you loosen and re-tighten them in the process. Let me know how you make out. The most difficult part will likely be the removal and replacement of the toe panel/kickplate. It is possible the upper rack glides/ball holders have worn, this is usually identified by the customer finding gray pieces of plastic on the bottom of the tub, like this image shows below. i.e. macmarkus_78.jpg If this is indeed something you've noticed, follow this link to replace them. http://www.fixya.com/support/t6589773-replace_rail_replacements_in Thanks for choosing fixya and Good luck, Regards, Macmarkus :)
Nov 24, 2010 | Asko 1375 Dishwasher
I have an ASKO dishwasher 1375 model in black. Can it be spray painted with bisque appliance paint to match my other appliances?
You can try applianceart.com, they have alot of different color and texture appliance covers.
Oct 20, 2009 | Asko 1375 Dishwasher
Top rack will not pull out all the way
Replace the upper basket wheels - these are available as spares. If the metal runners look angled - it may be the wheels on the side of the dishwasher that need replacing. These are also available as a spare part.
Ebay is actually a good place to shop for spares of this type.
Aug 04, 2009 | Asko 24 in. 1585 Built-in Dishwasher
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Asko 1375
May be the drainpump that has something stuck into it. Check that
Jun 08, 2008 | Asko 1375 Dishwasher
Dishwasher does not drain after cycle
Check the drain pump and/or drain hose. It may be clogged woth something.
Jan 26, 2008 | Asko 1375 Dishwasher
Upper rack travel sticks and jams.....
you have a bad bearing retainer. you will need to call an asko parts dealer and order 8 upper rack ball bearings, and two ball bearing guides (they are grey plastic and break over time, causing the rack to jam. To replace tham, you must take the upper rack out by turning the plastic retainers on the front of both rails 90 degrees towards the outside of the machine. The slide the whole basket out. Now look at the back of the rails inside the dishwasher. there shoul be 2 more grey plastic retainers with bumpers on them in the rear. These must be pried out wiht a screwdriver (be careful, have cut myself several times on this job till i figured out the best way to do it. cover the bottom hole in the dishwasher with a rag, as you are likely to drop the old bearings when you slide the rails out. Slide out both the rails. Put your new (or old if youve got all 8) ball bearings into the ball bearing holders, then put the holders into the rail thats attached to the dishwasher. slide the rails back in, andthen put all your retainers back in and your rack. you may have to slide the rack in and out a few times before it will center the bearings and work smoothly. Should cost you about $12 in parts. Good Luck!
Apr 17, 2007 | Asko D1716 Built-in Dishwasher
Asko 1375 Dishwasher Logo
308 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
