Question about HP Pavilion dv6000z Notebook
Restart doesn't work
When i try to restart computer,it shuts off normally,then starts up,goes to black screen with phenoux logo,then shuts off,turns back on,then repeats this cycle until it is shut down manually.please help
  • markfm1963 Jan 05, 2009
    will reinstalling os cause me to lose my files?
  • 100 Answers
Girl friend had the same problem Call HP support 18004746836 you may be eligible for a new motherboard. This model has suffered a bad bios overheating the motherboard and causeing these problems.
Posted on Jan 06, 2009
  • 520 Answers
Need more info but pc's usually do this if you
havent registed windows and your time limit to do so is up.
you can install os again and register if
thats the case
Posted on Jan 02, 2009
  • tat4u
    tat4u Jan 05, 2009
    could be sys files are missing or corrupted.
    boot form xp in choice menu select install...after diagnosis system informs os already exists ...install or repair....
    at this point you can decide which option you want .
    to install gives you a fresh copy and any previous files you may want or need will be lost ...to repair ...it fixes or replaces any missing or currupt files and restores pc to what it was like before fault and any previous software installed will still be there...everything working ...ps to install fresh copy or to repair existing os takes about the same time....so its just a case of whether you want a fresh copy which you also have to re-register or to repair and keep existing files..
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
Too many! Where do I start.... 1. The Wifi connection does not work, although blutooth is on and the blue indicator light is illuminated. 2. When the pc is idle for some time, the screensaver does not...
This can happen when there is two problems.. One the computer might have been affected by virus.. Or the other thing might be the OS corrupted.. Try to get into safe mode and check if the system is working fine.. If it works well there try to do a system restore to a place wr it was working well.. If in safe mode also it doesnt work well then go ahead and reinstall the OS...
Sep 24, 2010 | Computers & Internet
Acer aspire one
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
Mar 17, 2010 | Acer Aspire One PC Notebook
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
When It goes to loading screen it restarts
It is becasue of your computer is not properly shut down and so your harddisk has some bed indexing of memory location.
For that you need winxp disk or recovery disk.
Then boot your computer with that disk .
You have to set first boot device as your cd or dvd rom.;
For that when you power up press F1 or F2 or "del" key to enter in bios .
Then go to boot option then sewt first boot device as your cd or dvd rom.
then save settings then put winxp or recovery disk in rom.
Then follow the procedure .
Then enter in recovery console then type in prompt "chkdsk /r"
then it fix error on harddisk.
Sometimes this command fix eror and then after restart windows load normally but sometimes need to repair windows.
So after check this if still face issue just chose "r" when it finds your previous version of windows then it recovers your windows.
Let me know if you need more assistanse.
Thanks.
Sep 04, 2009 | Computers & Internet
Startup logo appears then it goes to a black screen and blinks
You should try booting into safe mode. Press the F8 key before the windows logo and choose safe mode without network support. If windows loads run a checkdisk by right clicking on the c drive, left click on properties and then select the tools tab. From there you can run a disk test to check for errors. If you get that far then reboot and see if it starts normally. If not try F8 again and try selecting restore the last known working condition. This will restore your settings from the last time it worked. If you can’t get to the F8 screen get back with me and I will try a few more drastic solutions. Good Luck
Jul 22, 2009 | Computers & Internet
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
HP Pavilion dv6000z Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
