Question about Apex Digital PF3230 32" TV
Help I have an apex tv 36inch...the colour goes black and white than later returns to colour.... if we unplug the digital cable than plug it back in the colour returns briefly..our channel is set for channel 3 for cable and vcr..and the picture goes to black and white but if u change it to another channel it shows a blue screen so there is colour going to other channels that the cable isnt running to???
  • 47 Answers
Not a home repair take it to a repair store.
Posted on Feb 26, 2008
Have a 4 year old flat screen Apex. Turn it on have audio but black screen. Checked, unplugged and re plugged everything. A couple of time the picture came back hours later and days later but not at all....
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 19, 2015 | Apex Digital LD4088 LCD TV
I have a Apex LD3249, I moved it too another room plugged it up and did the channel scan for TV Air. When it finishes the screen is black and it has the white box in the middle saying to do a channel...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 08, 2017 | Apex Digital Televison & Video
Turned my tv on and for some reason the DVD source is in black and white and controller not workin for it, TVs colour for other outputs and controller works only DVD that doesn't .
If you're using component cabling (red, green, blue cables) a black and white picture will occur when only the green cable is plugged in.
If you're using HDMI cabling, try a different HDMI port and see if your color comes back.
If not, unplug the set from power for a few minutes, plug it back in and see if problem persists.
If you still have the same problem, check the DVD player on another TV. If it shows color on a different TV, then your TV will need a replacement digital board which we can check availability on once we have a specific model number. If it's black and white on a different TV, then you have a problematic DVD player.
Dec 15, 2012 | Televison & Video
Dvd is playing movies in black and white
Hi
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Kolbrun
Feb 26, 2012 | Apex Digital ADV3800 DVD Player/VCR
How to run cables from apex porable dvd player to tv
before connecting the cables check the input and output terminals on the apex didital dvd player, there is a terminal output for audio and video reparately. the video and audio output terminals have been colour coded to prevent confusion, the yellow terminal is usually meant for video and red /white for audio. also check for the provision of a jack-pin input as this is where you can plug in your head set as you listen to the music
Sep 24, 2011 | Apex Digital Televison & Video
Why is my apex dvd player showing movies in black and white
check the connections, a lose cable will cause colour loss.
Mar 04, 2011 | Apex Digital AD 1115
TV suddenly lost colour - gone black and white Virgin Media.
most likely the problem is due to a "lock up" you need to reset the system, unplug the set, and look in the back panel (I am assuming it is a digital (flat screen tv?) for a small (usuall) red nipple, again making sure the power is unplugged, depress the nipple with a bll point pen for about 5 seconds, wait a few minuets, and plug the set back in, you will most likely need to go to your menu for set up again, but you will be starting with a clean slate (so to sleak) and the tuner should then correctly pass the signal though
Sep 15, 2009 | Televison & Video
Apex 19" #LD1919
1. UNPLUG the TV from the wall or power strip.
2. Turn ON the TV (w/o the power plugged in).
3. Plug the power cable back in.
4. Turn ON TV ... it should work...
5. Also... adjust antenna if you are on "broadcast" mode.
Sep 03, 2009 | Apex Digital LD1919 19 in. LCD TV
No Color playing DVD just black & White
Have you tried playing the DVD in PAL60,NTSC 3.35 or alternately select the colour system on the TV manually rather than in auto ?
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Apex Digital PF3230 32" TV Logo
176 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
