Question about Kenmore 62622 Electric Dryer
When operating, dryer makes sound like metallic rubbing
Dryer works OK but the rotating drum seems to be making sound like it is rubbing against something metallic. Sound seems to abate after dryer has warmed up.
Don't have manual and would like to know how to get at the inside of machine to see the belts, etc.
Have taken the back off and cleaned wiring area of dust, etc. Nothing appears wrong here?
Thanks
  • Anonymous Mar 27, 2014
    gasket/seal that appears to keep drum from rubbing against frame/housing. Drum belt is fine and motor is fine. Just seems like drum is binding up against frame/ housing, like it needs lubricant or something around the outer rim of drum. Drum moves up and down side to side, loose like something is worn that should keep it stable.?????
  • Anonymous Mar 31, 2014
    On my bicycle, the back tire has a rubbing sound only when I move tire forward. It sounds like it is coming from the metal piece in center of tire.
  • 91 Answers
IF LINT SCREEN ON TOP REMOVE 2 SCREWS, THEN SLIDE (pull) TOP TOWARDS U NOW,, DISCONNECT POWER FIRST,EACH SIDE HAS 2 5/16 SCREWS REMOVE ,UNPLUG DOOR SWITCH , PULL FRONT PANEL UP TOWARDS U NOW YOU CAN ACCESS WHOLE DRYER ,,REPL/ ROLLERS.IDLER PULLY SHOULD RESOLVE PROBLEM
Posted on Jan 03, 2009
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
Some unkpwn blackness appeared all over the inside of the dryer, it looks permanant. How can I remove this blackness?
That black stuff you see is probably from metal rubbing against metal. Check the front of the drum and make sure it rides on either thick felt, or nylon slides. Let me know, Ok?
Aug 09, 2011 | Dryers
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Jul 10, 2010 | Crosley CDE6000 Electric Dryer
When it rotates it gives metal banging sound what is the reason?
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 20, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
The drum is making a resonating sound when turning.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
May 23, 2010 | Bosch Axxis WTA 4107 Electric Dryer
DRUM MAKES NOISE WHEN TURNING ALMOST LIKE IT'S RUBBING AGAINST SOMETHING INSIDE THE MACHINE. SOUNDS LIKE DRUM IS TRYING TO STICK AT SOME POINT OF ROTATION.
check that all the support springs are connected and one is not broken. It is also possible that something is between the drum and the frame.
Sep 26, 2009 | Dryers
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Makes loud sound when spinning - seems like off track
The bearing is worn and now the drum support is rubbing against the metal mount. I do not know what type of dryer you have but my web page covers a lot of material. The dryer that is easiest is mentioned here, plus I have pages on your dryer as well.
READ MORE
May 25, 2009 | Dryers
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Kenmore 62622 Electric Dryer Logo
136 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
