Question about Frigidaire GLWS1233A Top Load Washer
Frigidaire gltf1670as0 Front Loading Washer
Just went to do was wont start door lock light comes one but does not lock. One month ago replaced timer cost me 125 bucks any help here?
  • 883 Answers
Door lock position switch may not have been properly tightened at factory. first position then tighten the switch
Posted on May 23, 2007
My control light blinks and beeps when pushing the start button. I have already replaced the door lock and switch assembly. Door lock light does not illuminate at any time.
Hello friend, thank you for your post!
Based off the information you have provided it sounds like it could be a possible issue within the control panel of your Frigidaire washer. I understand that you have replaced your door lock and switch assembly but it could also be an issue with the keypad of your appliance. I would recommend having a professional come out to properly diagnose your appliance to avoid unnecessary part purchases. I hope this is helpful. - Matt
Aug 21, 2014 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Not working
Good Afternoon James,
I see that you are still having trouble with your Frigidaire Affinity washer, model# ATF7000E, finishing and now starting a load, even after replacing the door lock.
I would start by making sure that your washer door is completely closed.
Next I would check to make sure that your washer controls are not locked. You will see a "LOC" code if the controls are locked. To get them out of the lock mode, press and hold the "Options" and "Select" buttons at the same time for 10 seconds.
If you are still having trouble you will want to give your washer a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
Once power is restored, if you are still having trouble with your appliance either not starting or not completing the cycle, I would recommend contacting either the manufacturer or your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
The door lock comes
doorlock switch needs replaced.adrian,,,,
Jun 28, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Front loading washer turn on door lock light is on wont run is it the timer
most likley to be a fulty switch in the door lock, its not switching off when the door is closed and the programer see's it as an open door so wont start the washer,,,its a safty thing? call out the repair man,,
Nov 10, 2009 | Kenmore Washing Machines
FTF2140ES0 Frigidaire Washer Won't Start
Yes - often times the plastic breaks from slamming the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Washing Machines
Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Dec 03, 2008 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Drum won't spin.
ck fuse on board with ohm meter in board ..cks open change motor bd..also possible door lock or door strike
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Front loading washer door lock
It has not been resolved yet. It has been worked on twice now. It has a new electric panel (not sure what it is really called other than the brain) and part of the motor has been replaced. Now apparently the heater core is not working. The tech told me the heater core probably went out which caused the other 2 issues. I suggest buying the extended warranty if it is ever offered to you. My washer is only 9 month.
Aug 29, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLWS1233A Top Load Washer Logo
649 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
