Question about Hotpoint RB526 Electric Kitchen Range
What does bad line mean - Hotpoint RB526 Electric Kitchen Range
My phone says line in use what does this mean? I cant use my home phone
That usually means that something else is plugged into the circuit that the phone is connect to and the other thing is using the phone. It could be some other things though like bad phone, bad connection to the line, phone is disconnected etc.
Mar 24, 2015 | Panasonic Lands Phones
2003 suzuki wont crank up
what car?, suzuki makes 100s. and what tranny it has.......??????
no crank is cause by only 3 things.
1: bad starting system.
2: bad charging system , making battery dead. or battery is bad.
3: the key line is dead , if A/T? the key line goes through the tranny
PRND switch (side of tranny),. must be in N or P to start.
3a; if manual tranny? the clutch switch fails.
can you start with a jump start?
that means the battery is dead, no charged or bad.
if not, then smack the starter with a hammer ,start now?
if not, hot wire starter, work now?
if not, make sure the Key line to the starter solenoid goes to way above 8v, when you crank, if not the cab wiring is bad.
that means, the key line from ignition switch to the starter is failing.
here's a no crankpage covering all that.
http://www.fixkick.com/nocrank.html
Aug 22, 2013 | Suzuki Cars & Trucks
Po421
po421 catalytic converter code [warm up catalyst efficiency below threshold bank 1] means the o2 sensor is detecting low oxygen in exhaust problem can be cat conv going bad---o2 sensor faulty-and or bad spark plug ....as to the p0441 evap system[-evap emissions control system incorrect purge flow ] this is a system code meaning any part of the evap can have problem will need to check the fuel lines vapor lines for damage or breaks-check purge valve -purge valve solenoid- canister- and vacuum lines
Apr 10, 2013 | 2003 Mitsubishi Lancer
A maroon line running from top of screen to the bottom
Hello; The width of the line means everything. If the line is razor thin, meaning one pixel wide, this is is very likely a bad LCD panel ( costs more than the TV sold for ). If the line is much wider say 1/2" give or take, the problem is the LCD controller or LCD timing ( same thing ) PCB. Much more less expensive! John
Dec 15, 2010 | Sylvania 6626LG 26 in. LCD Television
Line from top to bottom
A single black line means bad panel while colored line means controller bd. or ribbon cable needs to be cleaned and reseated.
Nov 09, 2010 | Toshiba Televison & Video
I have an older agneovo f419, she now has coloured lines running vertically up the screen, the longer the screen is on the more lines that come along for the ride. Can I fix the thing 19" are still a bit...
Hi Daz, try another working monitor on your computer and if the lines still appear on another monitor then that means your video card or onboard video is bad.
If you use another working monitor and the lines don't appear then that means that the original monitor has a bad screen and would not be worth the $$$ to repair.
Jan 06, 2010 | Neovo F-419 19" LCD Monitor
I got a vertical line on my lcd screen
lines on an lcd screen means the screen itself is going bad, if the monitor is under warranty then get it replaced, otherwise get another one. Also to verify this, try another known working monitor on the computer and if the lines go away then you know for sure the monitor is bad, if the lines stay on both monitors then you know that the video card is bad.
Jan 06, 2010 | Computers & Internet
Error code C2 showing on my Oko Favorit dishwasher. What does this mean?
Error Code C2 means drain line totally blocked.
Check drain valve for restriction in pump, check drain line. When there is no problem in drain line then check for a bad float switch or a bad control board . You will get this error even when there is no water in the tub . You can check the float switch with an ohmmeter. It should be open if the float is up and closed with the float down.
Hope this helps .
Thanks for using FIxya.
Dec 13, 2009 | Dishwashers
I have vertical colorful lines on the screen just got a new computer with windows vista
the monitor is bad if your getting vertical lines on it. Anytime you get vertical lines on any monitor, LCD, laptop LCD, etc, then that means the screen is bad.
Your monitor needs to be replaced.
Aug 09, 2009 | Envision Computers & Internet
Hotpoint RB526 Electric Kitchen Range Logo
375 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
