Question about Dell 1815dn All-In-One Laser Printer
Want feed paper
When you print you can hear it try to feed but sounds like roller is dragging
  • Anonymous Jan 24, 2009
    Sounds like it wants to pickup paper but won't. Now bypass tray won't either.
Would not feed paper
Posted on Jan 10, 2009
Hello, i have a HP Officejet Pro L7480 which did not cause trouble for 3 years, but now: PROBLEM WITH PAPER FEEDING - when trying to print something, the printer normally "tries" to grasp a...
Hi
If it attempts to feed and expecially when you hear a cricking sound. It means that the paper guide it too tighten that it holds the paper. Try to loose up the paper tray guide. Are you using a paper tray. If not, put small paper or change the correct setting of the paper size setting to auto detect if any.
The try to print again.
Mar 31, 2011 | HP Officejet Pro L7480 All-in-One...
Paper won't feed up to print
Try using Windex and a lint free cloth(not paper) on the feed rollers. The rollers may be glased due to age or use. If that does not work, call a tech.
Jun 25, 2010 | Konica Minolta magicolor 2400 Laser...
Hi! My name is Roy Napier and I have couple of problems for which I would like your advice. 1. On some occasions my print-out has faint extra "ghost" copies of the text etc printed plus the colours seem to...
My first suggestion to you is to remove, clean, shake, and reinsert the ink cartridges, then allow the printer to self align. Follow your manufacturer's recommendations for removal and insertion of the cartridges.
The dragging of colour that you mention is most likely attributed to the rollers which feed the paper. If one is dirty, it will affect the paper's print quality. The way that I suggest to fix the problem with dirty rollers is to obtain a long, continuous piece of brown paper towel (utility towels, like you find in factories) and insert the end of the paper into the multi-purpose feed, then feed it into the printer for a few seconds.
Once the paper towel has fed into the printer, extract the paper manually by pulling on it in the opposite direction of feed. Repeat this process a few times and the rollers will be clean, and the color scrubbing problem should cease.
Dec 29, 2009 | Dell 3100cn Laser Printer
Paper is not taken inside my printer
Its the paper feed mechnism problem. Try to clean the paper roll with cotton using warm water. if still the problem continue u need to replace the paper feed assembly.
Aug 18, 2009 | HP DeskJet 3550 InkJet Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper not feeding on the left hand side of our lexmark 5100
open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Nov 25, 2008 | Office Equipment & Supplies
Lexmark z715 problem w/printing
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Nov 10, 2008 | Lexmark Z715 InkJet Printer
Paper feed
Something is stuck in between the
tray and rollers possibly torn paper
in one of the corners
try with just a few sheets of paper
Once you remove the jam
wilthout breaking any plastic
parts it will work okay
Nov 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Paper will not feed
Check for a jam again somewhere in printer unit, rollers, teeth, down back in paper feeder area. I thought i had no jam in my unit either until i got a torch and found the tiniest slip of a shred barely noticeable right in the middle of the teeth/roller. Remeber to turn it off after this, to reset it.
Aug 16, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Dell 1815dn All-In-One Laser Printer Logo
73 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
