Question about Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up
Infiniti I30 Battery+Parking brake lights on
Yesterday my battery light and parking brake light came on. What could be the problem? Blown alternator? Bad fuse? If bad fuse, where is the fuse box in the pax compartment? I couldn't find it.
  • 1 more comment
  • beemoor2 Jan 08, 2009
    same thing now the car will not start
  • dhenne23 Jan 24, 2009
    First the battery light..then a few hours later the brake far the car still starts
    Same issue. First the battery light came on..then a few hours later the brake still is an 2001 I-30
    New Friend:
  • 15 Answers
The only thing your battery light and your brake light have in common is your battery and alternator. This happened to me and my battery was low because my alternator went bad. I suggest taking it to autozone (if there is one near you). They can test it for free.
Posted on Feb 28, 2009
My Parking Brake light has turned on and i don't know what could be causing it to stay on. Any suggestion would really help me out. Its a Chrysler Pacifica 2005.
Posted on May 10, 2012
Battery and brake lights on
John, According to Nissan forums weak failing alternator is the common problem for bat and brk light on. If you are sure battery and alternator are good, I say check and clean battery connections and all grounds(loosen and re tighten all ground connections to give good contact), check belt for being loose.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
. What would cause the brake and battery dummy lights to come on as your car...
Brake and battery lights on New alternator loose serpentine belt
Battery Light Brake Light on HELP
Mar 11, 2016 | 1997 Nissan Maxima
Brake lights are out on a 1999 infiniti I30
99 infiniti i30 brake lights not working - Nissan Forum ' Nissan ...
Apr 13, 2015 - hi, so my rear stop lights stopped working recently. but the brake light inside the rear window above the trunk works fine. that makes me ...
images for 1999 infiniti i30 wiring
Oct 02, 2015 | Infiniti Cars & Trucks
96 Town and Country parking lights not working
Try disconnecting your battery and reconnecting.
Your fuse may be blown.
If all else fails , you may need a new switch
Apr 24, 2014 | Chrysler Town and Country Cars & Trucks
Emergency brake and battery light on
Not sure of your model since it may not be sold in the US.
The light means the battery is not being charged or the parking brake is on.
You should have 12 volts at the back of the alternator with the engine off and 14 volts with the engine running. Also check and make sure the parking brake is off and the brake fluid in the master cyl is full.
Aug 24, 2012 | Chevrolet Optra Cars & Trucks
Brake and battery light came on while driving.
The battery may not be charging, alternator, cable, or fuse problem.
The brake system may be low on brake fluid. The parking brake switch may be telling the light the parking brake is on.
Jul 18, 2012 | 2000 Mitsubishi Galant
Parking brake light comes on while driving battery
your parking brake has a switch. when you push your pedal it activates the switch .if your pedal is slack it would let the switch turn on without you even touching the pedal.
battery light going on and off while your driving would usually indicate that your alternator is not charging properly. or loose battery cable.
Dec 09, 2010 | 2004 Mazda Tribute
2006 Hyundai Sonota parking lights come on when braking
Check grounds and connections at battery 1st.Also may have alternator not putting out correctly.
Jun 16, 2009 | 2006 Hyundai Sonata
I have a hyundai elantra 2001.. the brake light and the battery light both turn on.. what could be the problem...
Your alternator is probably not charging at full capacity. The brake light is next in sequence with the battery light, and will glow dimly. (Set your parking brake, and it will glow brighter.) I replaced the alternator, and cleared up the problem.
Oct 26, 2008 | Hyundai Santa Fe Cars & Trucks
My battery and parking brake light flash randomly.brand new battery and alternator has been checked.
Park brake light - might mean the e-brake pedal is slightly moved down to initiate light. Battery light - means the alternator is bad or battery bad etc
may be the battery wires are slightly connected
Jul 29, 2008 | Infiniti I35 Cars & Trucks
Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up Logo
1,940 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
