Question about Aiwa FR-TC5000 Clock Radio
Buttons I was just given this clock-radio from a friend. I can set the clock, but none of the other buttons function.
I think the best thing to do about it is reset your clock / the button should work than if not i will you some more with it
Posted on Dec 29, 2007
How do I set the clock on my acurite
Press and hold the SET button. when the two dots start to flash, use the hour button to set the hour and minute button to set the minutes. more accurate steps can be given if you share the make and model of the Clock Radio
Mar 02, 2016 | Audio Players & Recorders
My 10+ year old Bose wave radio/alarm on fritz
Replace the 3 AA batteries that maintain memory & backup alarm function. That just may do the trick.
Apr 10, 2010 | Bose Wave Radio
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
Sharper Image Alarm Clock won't reset after changing battery
  • https://www.sharperimage.com/si/pdf/manuals/204050.pdf
Jan 06, 2018 | Audio Players & Recorders
I can not figure out how to set the times, or the alarm for my new Clok Smooth iPod Docking Clock Radio - TCR368 manual. it did not come with a manual or instructions of any kind.
1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
Nov 28, 2008 | Digital Products International Clok Smooth...
I can't set the clock on a DEH0-2050MPG car radio. When I press function as the manual says to, only 2 options appear, and neither have anything to do with the clock. What do I do?
If the function button does not work to set the clock, you have to turn the radio off, and hold down the source button until the clock appears. When the Clock appears, you can set it by using the four smaller buttons around the source button.
Jul 22, 2008 | Pioneer Audio Players & Recorders
How to set time
http://www.emersonradio.com/owners Copy this web link and paste it into the address bar of your browser. The link will take you to the Emerson customer support clock Radio Owners manual directory. Here you can find you Type of radio and open the link and find you model. Open the model link and then you can follow the instruction given in the manual to set the clock. I hope this information helps you with your problem.
May 09, 2008 | Emerson Smartset Clock Radio
Setting clock
Goto...
http://www.crutchfield.com/S-a8d6UElCbSr/App/Product/Item/Main.aspx?i=105KDPDR30&tp=5684&tab=detailed_info
has some info on our problem.
Hope this helps
Dec 25, 2007 | Car Audio & Video
Non-responding buttons
maybe you have defective crack board! or lost contact at the board! or clean all tact switches.
Oct 02, 2007 | Emerson CKD9901 Clock Radio
I can't set the clock!
Okay, I had the same problem as well. After reading some solutions that didn't work I figured it out. On the right side of the radio there is a "F" function button on top and "A" audio button on bottom. First turn the radio off. Push the clock button until it is displayed. Then push and hold the "F" function button until the radio comes back on, then release the "F" button for a second and push it again then relase. Now, at this time the radio should only display the clock with the hour blinking. Use the up and down select key to change the time. Then push the right or left select button to change to the minute which will start blinking, then again push the up and down select button to adjust the minutes. When the time is correct just push the clock button and it is set.
Jul 23, 2007 | Pioneer DEH-P4100
Aiwa FR-TC5000 Clock Radio Logo
90 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
