Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
My Dacor wall oven will not turn on , control panel is saying u60 cooling fan.
  • 30 Answers
If you can have an electricain check to make sure the wiring is all good that would be a start. It is NOT uncommon for a wire to come loose. If that is OK then you need a new fan. If the fan is not working or working properly then the unit will not work at all. With out the cooling fan the oven could overheat and start a fire.
Posted on Apr 26, 2009
Im getting this message u60 cooling fan can some one tell me the meaning? Thanks
There is a small fan you should be able to hear blowing when the oven has been hot for a while. The fan keep the electronic controls cooler so they won't be damaged by the heat.
Aug 21, 2009 | Dacor MCS130 Millennia Electric Single...
U60 Cooling Fan message on Decor MOV130
First, try to clear the code. To do this you must push and hold # and 'cancel' at the same time until the screen asks for an ID code. Then type in (using the key pad) S1234 (you get S by pressing 7 five times) Then simply press 'clear all' and the code should disappear.
Add a comment
    • 530gonzo
    • 51 seconds ago
    If that doesnt work then pull the oven from the wall by removing the door and unscrewing the stainless steel trim. Pull the oven straight out and attatch the pull handles to pull it completely out. Next, place the oven on a secure stand (such as a milk crate). Then turn off the breaker to all electricity in your kitchen and confirm the power is off. Then, using a 'Torx' brand bit, take off the sheetmetal cover on top of the oven. Download a service manual to your oven and check power to the fan as described in the manual. You can find service manuals on the web (do not use owners manuals) Next, check power at the Hall effect sensor as described in the manual. You just need a volt-ohm meter to do these tests. The manual describes it well. If these tests confirm the fan is not defective, you need a relay board. Dacor part #101559. I got one for $165 last week from Dacor. 99% of the time this is the problem and the boards are even back-ordered. Dont be critical of Dacor, the ovens work well. My advice is just to buy the extended warranty when you get one. Like any high performance machine, they run well if cared for by experts.
Mar 21, 2009 | Ovens
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
Apr 09, 2008 | Dacor ECS230 Epicure Electric Double Oven
Control panel fan won't turn off
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Jan 26, 2008 | Dacor Epicure 30" Double Wall Oven,...
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
Feb 05, 2007 | Dacor Millennia MOV130 Electric Single...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
310 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
