Question about Waterway Spa Pump & Hot Tub Pump 1.5" Plumbing C75115
Hot tub maintenance
I'm considering a Vita spa and a Marquis spa. The Vita spa's owner's manual looks like it requires much more upkeep. Is this true, or is the Marquis spa manual just minimizing the amount of work?
DRAINING AND REFILLING BALBOA HOT TUB
Posted on Oct 24, 2009
  • 125 Answers
There will be the same amount of basic maintenance on either spa. The difference will be in water chemistry. you definitely want an ozone generator on either spa. Both are awesome Mfg of spas. they both have been around since the 1980's
Ozone will keep the water cleaner, fresher smelling and reduce the total amount of traditional chemicals used in any hot tub.
There are many other solutions for taking care of water chemistry out there without using the traditional types.
some are all natural.
Posted on Feb 26, 2009
2 Suggested Answers
  • 366 Answers
SOURCE: just looked at 2000 coast spa hot tub with 1 6.5hp
a 6.5hp motor produces quite a bit of force. It should be able to support 30 jets just fine. Most spas range from 2hp to 7hp. Depending on your preferences, the 6.5 should be plenty but if you really want a powerful therapy jet, two 7hp pumps should be more than sufficient. They will also kick your electric meter up a few notches...
Two pumps give you more options, you don't have to have half of the jets turned off so one area can have more power, the dual pumps give you the option to run nearly all of the jets at the same time if you have more than just a couple people in the spa a once.
Posted on Nov 09, 2009
I bought a used Leisure bay Proshield hot tub and looking for an owners manual
I found a link on Google to download the PDF format. www.thespasyndicate.com or www.SpaParts123.net.
Sep 28, 2017 | Leisure Pool & Spa
Want manual for Marquis spa ME-33-B-Y-082212
hot tub manuals ' guides ' Marquis - Marquis Spas
www.marquisspas.com/hot_tub/manuals.asp
Marquis has indexed our hot tub manuals and hot tub guides. ... 2010 US OwnersManual · Wish Insert · Euphoria Insert · 2010 EDHT Owners Manual. 2009.
[PDF]OWNER'S MANUAL INDEX - Marquis Spas
www.marquisspas.com/documents/2009/09MQIntlEnglishManual.pdf
Failure to use, maintain or install the spa in compliance with this owner's manual could result in ... This symbol indicates the need for separate waste collection of ...
[PDF]owner's manual - Marquis Spas
Dec 30, 2015 | Cars & Trucks
Error codes
Here is a link showing the most common error codes for hot tubs using Balboa Instrument spa packs.
Balboa Direct Factory Direct Balboa Water Group Bath and Spa...
Rod
US Parts Center
Nov 16, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a vita duet spa. It has a pb error and the jets or the lights will not turn on. Any suggestions?
Vita Spa Error code (PB) is a power board communication error. Turn off the power and then check the connection between the topside control and control box. check for loose or unplugged wires, unplug the topside control (after turning off the power) and check for signs of shorts or charring on the wiring ribbon/connectors. If you cannot find the source of the problem you will need to contact your dealer or repair technician. I hope this helps =)
Nov 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Need manual for a vita bijou hot tub
Vita Spa is now out of business, so contacting the factory isn't a option. You can try googling for an online manual download. They usually cost between $10 and $15.
Jun 14, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Hot tub not heating need owners manual to reset
You need to provide the exact make and model of your spa
Dec 12, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Hot tub
go to the manufactures website or just google (the name + service manual/owners manual)
Apr 10, 2009 | Waterway 4 Hp 230 Volt 1 Speed Side...
Waterway Spa Pump & Hot Tub Pump 1.5" Plumbing C75115 Logo
493 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
