I have a Casablanca Ceiling Fan (Model 652T) from 1980. It works well except that the pull chain switch has broken and needs to be replaced. The switch has a pull chain and 3 lead wires and is marked "Leviton 689, 3A-250V 6A-125V-T". The Leviton catalog shows a model 1689-50 2 circuit, 4 position single pole pull chain switch. Is that the correct one?? I need this switch to turn the fan on and off and the light on and off. Thank you, Eric Steele
    Problem Solver:
  • 20 Answers
The switch will work ,there are a lot of universal ones out there . but a fan speed switch can't work the lite also
Posted on Jan 09, 2009
Casablanca Trident ceiling fan issue - light suddenly stopped working - replaced bulb to no avail - fan works fine otherwise...ideas?
Is it powered from the same breaker as the fan, check the breaker, if so check the connections. Most likely if its a pull chain switch the switch is bad,,,,, it's common..
May 29, 2014 | Dryers
Finding a light kit for a casablanca 652T fan
That's an old model so I don't know without seeing a pic for sure. If it has three screws on the bottom plate,you have to use an older Casa. light kit or almost any Bowl light should work. fanman9952@aol.com
Mar 27, 2013 | Dryers
I have a Casablanca ceiling/fan light with one wall switch. The fan will only work on high speed and makes a shrill type of noise. The light has worked but not consistently. I was wondering if I have a...
is the switch made to turn on and change the speed, the switch is acting up should chang the switch, but if you change the speed with the chains the wiring is loose up in the fan just need to take it down and tighten up the connections,good luck.
Aug 08, 2011 | Casablanca Fan 3245T Ceiling
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
Just bought the house- it has a casablanca del mar but no remote- the wall switch does not work- can i override the remote?
usually remote control for ceiling fans does not have an override code like the ones available for control using a universal remote. because they are specifically designed to work with certain IR or Radio frequency signals.
Usually a replacement remote is available but you may have to contact the manufacturer to check for availability.
Here's Casablanca Support phone number:
Call Toll Free: 1-888-227-2178
Hope this helps!
Aug 03, 2011 | Casablanca Fan 3845Z Ceiling Fan
Hampton bay ceiling fan works, but can not change speed or stop fan. Model 46006 52" Huntington III. Is there an easy fix?
your pull chain for the fan is bad u can go to home depo & buy a new pull chain but when u replace it on the back ot the switch their is A 1,2,3,4, make sure the wires go to the correct #'s
Oct 05, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
We are installing a lighting fixture on our Casablanca 4944D Concentra. We can get current across the various wires, but can not get the light to turn on. The colors of the wires are blue, black, red,...
On ceiling fans, the blue wire is designated for the accessory light kit. If you are using the Casablanca kit, it should be wired with a matching plug that just, well, plugs into the fan.
If you are adding another brand of light kit, you only need to connect the blue wire (hot/common) to the black wire of the light being attached, and the white (neutral) to the white wire of the light being attached.
Your fan will not have a pull chain/switch for the light attachment, as that is normally supplied pre-wired and installed in the light accessory.
If in doubt about about the wiring, contact Casablanca for a manual showing what light kits are acceptable for adding onto your particular fan model.
Also, please turn off the power before connecting the light kit to the fan.
Hope that helps and best regards!
Jul 31, 2009 | Casablanca Fan 4944D Concentra Antique...
Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
Jul 16, 2008 | Casablanca Fan 3245T Ceiling
Heating & Cooling Logo
800 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
