Question about HP LaserJet 1320 Printer
Hello, I have attached the hp laser jet1320nw to my mac. The mac says the printer is ready, however the light flashing on the printer beside the symbol triangle with a ! in it is on...first time I've installed the printer. I do not have the instruction booklet for the printer. What do I do?
    Problem Solver:
  • 82 Answers
Install the printer driver which you would have got from the printer you buyed...........if this does not help go to hp.com & download the driver with the mentioned model...............hope this will help you..................Sameeraryan
Posted on Jan 02, 2009
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Hp laserjet m603n flashing orange warning light and says "ready" then changes to "please wait...checking printer" sitting like this for days now. When I reboot withought the ethernet cable it boots u
    What do you mean by "When I reboot without the ethernet cable it boots u......?" It boot ok and the flashing orange light, stop? Try using a local USB connection to a nearby computer and see if it works.
    Jan 18, 2013 | HP Laserjet 600 M603dn Laser Printer -...
    HP M2727 printer has FLASHING attention and ready lights
    leave printer on, and unplug the power supply, then wait10 min. plug it back in, this should reset the printer, you might have to do this again and unplug any connections to your computer, wait and then plug in printer with power off and plug in connection to your computer, then turn on printer,, check your ink levels when you power up. if ink levels are low ,you could get this error. if this don;t work go to your printers website and check there solutions or you might have to call them.
    Oct 02, 2012 | HP CB532A - LaserJet M2727NF All-in-One...
    My HP laser jet 4250n printer turns on but the display screen is blank --there is no message. the ready light, data light and attention light all come on
    Could be bad Control Panel or bad Formatter.Start with the Control Panel, it's cheaper.1st make sure the cable is attached to it.
    Sep 29, 2011 | HP LaserJet 4250n Printer
    Out laser 2300 printer has ready, data and attention lights flashing and we cannot get anything to prine- we have tried cold reset and other suggestions and nothing seems to correct our problem- any...
    All three lights flashing indicates a general failure. this is caused by either a bad connection, a bad formatter or a bad engine control board. Disconnect any cables you have attached to the printer and restart. If it starts fine then you may have a bad cable. If this is a networked printer, then it is quite possible that the network card has failed. You can try removing the network card if it has one and restarting. The JetDirect 615N card that shipped with this series of printers is notorious for failures.
    Sep 06, 2011 | HP LaserJet 2300d Printer
    Blank screen
    cartridge sensor eror or cartridge not detect or paper jum
    May 18, 2009 | Samsung ML 2010 Laser Printer
    Error Code 51.2 C on an HP 4600
    A 51.2 error message means that there is an error 51(Printer Error).2 (Laser Error) C (Cyan). This basically means that there is something wrong with the laser and the cyan color laser.
    Reference via HP Website, Click Here
    To Fix the problem:
    1. Press the green c00224695.jpg (Select) button to continue.
    2. Turn the printer off, and turn it on again.
    3. Perform a cold reset.
      1. Turn on the printer.
      2. Watch the control panel.
      3. When the memory starts counting, press and hold the c00224695.jpg (Select) button.
      4. Continue holding the c00224695.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
      5. Release the c00224695.jpg (Select) button when the Ready, Data, and Attention light are on steady.
      6. The control panel will display SELECT LANGUAGE .
      7. Press c00224697.jpg (Down Arrow) button once. The control panel will display COLD RESET .
      8. Press c00224695.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
    4. If this message persists, contact an HP-authorized service or support provider.
    Mar 21, 2009 | HP LaserJet 4600 Printer
    Problem with printer all buttons flashing
    All lights flashing is an error indication. to learn the problem you'll need a service manaual. The procedure is to hit the Continue button twice - see which lights flash (secondary code) and consult the manual. Then repeat that step and look up the final code (tertiary code) in the manual. This should be the problem.
    Aug 05, 2008 | Lexmark E321 Laser Printer
    All available lights on printer are flashing
    More or less your printer fuser has gone bad. Replace the fuse. I suggest that when buying a printer you don't with dell 1710N these printers gives a lot a problem. I work with them every day at work.
    I suggest that you go with HP.
    Oct 09, 2007 | Dell 1710 Laser Printer
    HP LaserJet 1320 Printer Logo
    46 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
