I want to know if my DVD drive can burn DVD's
I have a Philips DVD R/RW Drive
DVD8801/96;9305 046 68096
  • mgy101 Jan 06, 2009
    II also have problem with Samsung DVD R-120, even I call tech support they send me upgrade for frame , it doesn't work at all , this is the worst dvd recorder I had , it just waste my time and my dvds either +/ - , non of work period , this is garbage it belong to trash
    Thanks Mulu
dugiehowsa
  • 114 Answers
SOURCE: DVD drive not recognized as RW
If you use the Nero Smart start, you should see an icon to switch from burning CDs to burning DVDs. Once you click this icon, you should be able to burn to DVDs. Step-by-Step tuturials can be found for nero products here" Nero 7 http://ww2.nero.com/nero7/enu/Tutorials.html Nero 6 http://ww2.nero.com/nero6/enu/Tech_Support.html
Posted on Sep 18, 2006
  • 158 Answers
SOURCE: CD-RW/DVD-ROM BURNER
if you wish to burn cd's which is your burner then you need a software called nero burning rom or any other burning software that lets you burn data or audio cd's or vcd's to burn with if you wish to burn dvd's then you need a dvd burner combo drive which lets you burn dvds
Posted on Aug 13, 2007
  • 8 Answers
SOURCE: SONY DVD RW AW-G170a
This is a problem with the DVD Writer model. SONY DVD RW AW-G170a has problems reading DVD+/- R/RW Discs. But there is no problem with any of the DVD+/- R/RW Dual Layer, DVD Ram or CD+/- R/RW Discs. It is the reason that this DVD Writer lacks the correct bitsetting for DVD+/- R/RW Discs. There is nothing else you could do other than replacing the wirter with some other model.
Posted on Aug 14, 2007
  • 2427 Answers
SOURCE: ATAPI DVD+RW Burning Problem
DVD / CD-RW is usually a a combo drive
DVD PLAYER with CD BURNER
DVD-RW is a dvd rewritable drive
Posted on Dec 30, 2007
  • 3 Answers
SOURCE: CD RW/ DVD RW Drive Will not read and Burned discs or burn to blank discs
I suggest a firmware update from Toshiba. If this does not help then your laser in the drive is no longer capable of this task. Also just thought about it but make sure the media that you are burning to is the same as the drive + or - R's
Posted on Jan 24, 2008
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
I have a philips sullivan tobago dvd /-rw, installed in a dell inspiron 1501 and guess what it won't do anything. can't watch a dvd, can't burn any type dvd, nothing nada. is there help? dell says it is a...
please tell us more about your drive. is it a DVD-RW or DVD+RW or +/-? note that + and - symbols, that's important, cos a DVD-RW can't write to a DVD+RW disc, but a DVD+/-RW can write to both.
Dec 15, 2008 | Computers & Internet
What dvd do i use for philips dvd recorder r610 is it plus or minus can you please answer this
Depends how its marked if its DVD-RW it use minus, if its DVD+RW its uses plus. If its
DVD-RAM its for DVD+/-RW (and CD-R, CD-RW, DVD+/-R).
Dec 09, 2008 | Televison & Video
Philips DVD+RW SDVD8820 does not recognise burned CD or DVDs
it could be upper and lower filters in registry and system files, use a removal tool called filtercheck 4.6 in CDR-zone.com (goto the forums and search for filtercheck)
after you downoad, run it, click yes to all filters found to remove. close program.
reinstall your preferred burning app (1 prog installed at a time and test burn)
this is to replace the filter entry that was corrupt
Nov 09, 2008 | Computers & Internet
Philips dvd burn not burning?
1. see to it that you have set your burning software to write to the disk.
2. try to use it on a cd, if it finishes the job, something is wron with your dvd drive.
3. make sure that the drive you have is really a dvddrive and not a cd drive.
4. upgrade youe burning software.
Jan 05, 2008 | Philips (JR4DVDRWK/00) DVD+RW Burner
Philips DVD+-RW DVD8631 will not recgonize or burn blank DVDs
okay guys here's your solution use memorex dvd-r disc in these drives these are the most compatable disc out there.
Nov 26, 2007 | Philips (DN4S2S05F/17) (5 Pack)...
DVD-RW Name Changes When Blank DVD Inserted
p3, Did you try burning the DVD and it failed? You should try upgrading the firmware on DVD drive. http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=ODD+Products&typecode=300400&subtype=DVD+Writer&subtypecode=300405&model=TS-H552U&filetype=FM&language= Or, your just interested why Windows is calling your expensive DVD burner a measley CD Drive? Your Burner is an all-in-one.(I think) It plays(and burns) cd's and dvd's. Whatever program you use to burn has not informed Windows of its true intentions yet...Which is to burn a dvd or a cd. It doesn't know what you are burning until something tells it to. Let me know what happens. Good Luck, Tim
Mar 06, 2007 | Samsung 16x (TS-H552U/BEWN) DUAL LAYER...
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
