Question about Orion 2500D Car Audio Amplifier
Wiring for 2500d orion amp
I have a 2500d amp. i'm getting power cause the red light has came on but i'm not getting no sound at all from the output of amp. i hook up another amp and it played. do i have to have a ground wire going to both as well as hot wires for it to play.
  • 49 Answers
Ground wires(heavy black)is connected when the red light lit.so no need check the red hot wire which is connected to battery terminal maybe loose.or theres no power comming in.thre are 2 hotwire in that amp one is red which is the main and yellow or sometimes orange which is the remote on. now if you sure that the power terminals is properly connected,ur speakers is working and input wires are good and still no sound. your amp is probably gone...do not try experimenting the wires or hook up two amp by any means..u might destroy all ur amp. hope this help u....
Posted on May 11, 2007
  • marcial  nasi
    marcial nasi May 11, 2007
    just check the power terminal fuse and fuse socket...check if both red and remote supply has power...
How do you wire it in? Orion 300 prq equalizer
the prq can be used after a head unit before crossover and amps. it is a preamp/equilizer and you must have an orion amp in the signal chain that uses the 5 pin din plug to provide power to the prq via phantom power. if you have a crossover it must be a brand with the same 5 pin din pinout input and output. the din pinout is 1\+15v, 4\r. ch input, 2\ground, 5\l. ch input, 3\-15v. left to right or clockwise on din. the power can be supplied to the prq with an optional 100 pps power supply unit. rca from head unit feed the input and the 5 pin din is the output .
Aug 09, 2013 | Orion 2500D Car Audio Amplifier
WHERE IS THE POWER FUSE ON A ORION 2500D
If the fuse is not on the outside of the amp, usually near the live input. it will be inside the amps casing. you may have to look around carefully as maybe under parts or hidden. if not on ouside of amp, 100% its inside the amp
Feb 27, 2011 | Orion 2500D Car Audio Amplifier
I have an Orion 2150sx and an Orion xtr2150 will either of these run on a one ohm load ? If not what is the best way to run either of these amps to get the most power out of them. I have two Orion xtr...
EITHER OF THEM WILL WORK AT ONE OHM WITH NO PROBLEM, MAKE SURE YOU MAINTAIN VOLTAGE INTEGRITY, USING EITHER 2 OR 0 GUAGE POWER AND GROUND AND A POWER RATED ALTERNATOR AND BATTERY.
Nov 03, 2010 | Orion 2500D Car Audio Amplifier
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Wiring diagram
Hello rivertoyz,
If your F250 has the stock radio, there are no preamp outputs, so you will need to use the speaker outputs. The best solution would be to wire a LOC (line output converter) to the rear channels and run RCA cables to the amp.
Speaker wire color code:
Left rear positive - Gray/Light Blue
Left rear negative - Tan/Yellow
Right rear positive - Orange/Red
Right rear negative - Brown/Pink
You'll need an amp wiring kit with 4gauge power and ground. Both the LOC and wiring kits are available at numerous online stores. The best service is from www.crutchfield.com. Another reputable online seller is www.sonicelectronix.com.
You did not say what subwoofer(s) you intend to use with the amp. If you want to stick with the Maxxsonics product, a pair of 10" Orion HP10D2's would be an excellent match. Wire each of the subs dual voice coils in series for 4ohms, then parallel them to the amp for a final load of 2ohms. Both of the linked retailers above sell the Orion's and many other brands as well. Just make sure that your sub selection has adequate power handling capability. At least 1000 watts RMS if you use a single sub and 500 watts RMS if you go with 2.
Hope this helps.
Jun 01, 2009 | Orion XTR Pro 2400 Car Audio Amplifier
*amp to sub wiring help...
The 2500D has 2 "+" and 2 "-" power connections to help split the current between two smaller wires vs. one giant, hard to route wire. According the manual, for optimal performance, both "+" and "-" power connections should be utilized. They also recommend using 4AWG wire for these connections.
The 2 "+" and "-" speakers connections are only there to simplify the wiring of multiple speakers into the amp. Both "+" get tied together inside the amp, as do both "-" connections. In this case, with the dual 2 ohm voice coils on your 12" sub, you would wire one voice coil to one +/- set on the amp and the other voice coil to the other +/- set.
Mar 03, 2008 | Orion 2500D Car Audio Amplifier
Im not get any loud base, even with the gain at full turn
an orion 2500d requiers 2 4 gauge power and ground wires to work properly.
Aug 22, 2007 | Orion 2500D Car Audio Amplifier
Boss 2500d gets hot and trips off and on every 5 mins...
If you are bridging the amp then you must DOUBLE the "ohms load" that is specified. I.E. If you need 4ohms per channel, then when bridged you would need 8ohms per bridged channel. If your load is indeed correct then you have a fried output probably. Try to run it without any speakers on it. If it still gets hot then you for sure have a fried amp. All the symptoms you decribe sound just like you have too much of an "ohms load" though.
Aug 01, 2007 | Boss Riot 2500D Car Audio Amplifier
Volume fluctuates???
-Your head unit has a sound monitor that increases volume to compensate for road noise. -Your amp isn't receiving enough power.
Oct 23, 2006 | Orion 2500D Car Audio Amplifier
Orion 2500D Car Audio Amplifier Logo
340 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Morne Olivier
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
