Question about Sharp R-1492 Microwave Oven
The unit made a pop noise and started smoking and smelled like burning rubber. Is the unit done?
    Scholar:
  • 56 Answers
I WOULD SAY SO! Most likely the power inverter board shorted out.
Sounds like perhaps someone put something with metal inside the unit without knowing and turned it on. Doing this tends to overheat the power inverter board causing a short in the system.
Be safe than sorry, replace the unit with a new one for around $100US. Lowes Home Improvement centers have some that are very inexpensive and are available in brushed stainless steel to match most kitchens.
Cheers,
Keith
Posted on Jan 02, 2009
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
Our JVM1850 makes strange noises, its lights flicker, the microwaves smokes and the unit emits a burning plastic smell. This unit is only 1 1/2 years old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | GE JVM1850 1000 Watts Microwave Oven
Panasonic NN-T785SF microwave smoking and popping
Not to worry ,Please use a good torch light or lamp to look inside the microwave cabin. On the side where the magnetron is fixed look for any food particles which could have stuck while heating. Use a good cleaning solvent to do this job. You must remove all the roller and plates and clean dry. Once you have done this open the top cabinet with the mains wires disconnected. Look inside the side panels for dirt, insect which have got entangled and cooked. use a good brush and blower to clean dry. If the main capacitor has leaked replace with a similar type. Get help if you are not able to do this as it is a dangeorus section with high voltage. You will get to the smelling part once you had inspected these areas. Replace the part in question, can be even the surge protector at the mains end. Hope this helps. Good day
Jul 19, 2010 | Panasonic Microwave Ovens
Maytag micro shot smoke. Left burnt smell
That would be my guess t possibly has shorted out.
Dave
Feb 05, 2010 | Maytag Appliances Over-the-Range Microwave...
We have white
there is a component called a spatter gard inside the oven at the point where the microwaves enter......if food or other foreign substance gets stuck there, then it will start to burn ...the smell and popping noise is coming from the spatter gard.....to fix it you must remove the spatter gard..replace it if it's burnt and /or sand paper the spot clean and then paint the area with a high temperature paint called mr. touch up......to protect the bare metal from the microwaves.....hope that helps
Nov 27, 2009 | Kenmore 80412 Microwave Oven
Kenmore over the stove microwave will not heat 1996
YOUR MAGNETRON IS MOST LIKELY BAD. THIS IS THE UNIT THAT CREATES THE MICROWAVES.
Apr 11, 2009 | Microwave Ovens
KitchenAid KHHS179lss, fried magnitron?
If your magnetron was shorted, the unit would not heat at all.
The sound of a shorted magnetron is usually a loud hum-- but no or very little smell and no smoke.
Components in the High Voltage section -capacitor, diode- give problems if they short out.
Feb 17, 2009 | KitchenAid KHHS179LSS Convection /...
FLASHES INSIDE OF MIRCOWARE AFTER IT IS STARTED AND MAKE NOISE
It could be a magnetron sparks to the open metal inside the m/w cavity or some broken wire on high voltage side. It is not HV transformer (when burn create a lot of smoke and bad smell). Magnetron needs to be replace.
Dec 03, 2008 | Whirlpool GT1195SH Microwave Oven
Sharp R-1492 Microwave Oven Logo
187 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
