Question about Iomega Zip 100MB (31714) External ZIP Drive
I have old Iomega floppy 100 MB diskettes; need to access them
Is there hardware available?
  • 416 Answers
You might be able to get some drives, not sure on warranty, nowadays mostly it;s USB Flash Drives
Posted on Jan 02, 2009
Iomega floppy drive model Bxxu0130, part no. 31062400. I need driver for windows 10 operating system. can you help?
There are no working drivers for windows 10 for floppy disk as it is an old hardware sorry
May 10, 2017 | Iomega Computers & Internet
I have a usb portable diskette drive that says compatabible upto windows 98 I have windows 7 can I download drivers for it?
If it won't plug and play then your basically out of luck. That is a very old device. If you still need to access floppy's i would purchase a newer device or have an internal floppy installed.
thank you,
Jul 26, 2011 | IBM USB Portable Diskette Drive (05K9276)...
I have an external Iomega 250 zip drive with a USB connection cable but do not have the power cord/transformer. Where can I get a replacement and will this drive (model Z250USBPCM) work with an iMac?
Yes your model will work with an iMac conveniently. The replacement chord can be gotten from any computer hardware store around. All you have to do is take the unit there so they can access what particular chord is going to function for it.
Hope this solution has been helpful?
Aug 25, 2010 | Iomega ZIP 100 MB SCSI (10011) External...
Apparntly I have DRLS120 SUPER DISK DRIVERS ON MY COMPUTER AND I CAN'T VIEW MY 2HD 1.44 MB FLOPPYS USING MY 31/2" FLOPPY DRIVE. How do I remove these drivers so that I can use my floppy drive?
If functioning correctly, the hardware of the Imation LS-120 devices can read/write 1.44MB diskettes, using "magnetic" hardware, and can use the built-in laser to read/write the proprietary 120MB "SuperDisk" diskettes.
What problem do you have?
How about taking the diskettes to a friend's computer, along with a USB memory-stick, and copying files from the diskettes to the memory-stick?
Oct 31, 2009 | Computers & Internet
How big the memory Stick as to be to transfer 12 **** Verbatim 2HD Formatted 1.44 MB how many GB do I need
If you are taking about 12 floppy disks a 1GB USB Flash drive is more than enough. 12 Floppy disks is only 17 Megs far below a 1 GB
Oct 11, 2009 | SanDisk Computers & Internet
Have bought a second hand IBM USB Portable Diskette Drive. It worked just fine at the sellers place. Now that I try and use my own PC I load a 1.44 Mb diskette and it tells me to load disk ??? What to do...
Hi Graham,
Your Portable USB 3.5 diskette drive uses a pretty old technology that would come with software or drivers needed to run it. You would need to check on your device manager on control panel. But I would advise you upgrade yourself to better storage devices like the flash drive or the CD/DVD USB portable drives. They are a bit more expensive, but the technology is newer and have less issues. Let's face it, the 3.5 diskettes are getting pretty outdated. Don't you think so?
Cheers & Kind Regards
Sep 24, 2009 | IBM USB Portable Diskette Drive (05K9276)...
I had a computer with a slot for reading iomega ZIP 100 disc. My new computer does not have this. Is there a device to read my zip dizc and send the contents to a USB port?
IOMEGA make a USB ZIP drive that reads and writes 100 and 250 Mb disks. Don't know if this is available any more, you might be able to pick one up 2nd hand.
If you still have your old computer, try networking your old and new computer together so you can transfer data from the ZIP drive on your old computer to your new one.
Mar 21, 2009 | Iomega Zip 100MB (31714) External ZIP...
Can't read specific Zip 100MB Diskette
Its probably a bad disk. The only way I have been able to fix these is to First launch disk utility THEN put the disk in. THEN run the utility. You have to do it in this order. The key thing here is utility has to be running first and then insert the disk "HOT"
Hope this helps!
Jan 22, 2009 | Iomega Zip 100MB (31714) External ZIP...
Metal sleeve
Below we have represented a picture of the now commonly used 3.5" floppy diskettes. The below representation is what the back of a floppy diskette looks like. As you can see there are four main visible parts:
floppyd.gif First, the top left of the back of the floppy there is a small tab. This tab enables the floppy disk to be switched from write protected and un-write protected. Move the tab to the top position, creating a hole, makes the disk write protected. This means that nothing can be written, erased or deleted from the diskette. Moving the tab to the bottom position allows the disk to be un-write protected, which means the diskette can be written too, erased, and or have information deleted from the diskette. Some diskettes, which are generally cheaper diskettes, will be missing this tab. To write information to the diskette you will have to place a piece of scotch tape over the hole.
Second, the top right hand of the back of the floppy you will notice a small hole. This tells the computer if the diskette within the computer is a High Density diskette.
Third, you will notice the circular metal disk in the middle of the floppy diskette. This is used to rotate the magnetic medium within the floppy disk casing.
Fourth, you will see a metal door which can be moved left and then will snap back to its original position. This door is used to allow the read/write head within the floppy drive to have the capability of accessing the magnetic medium within the casing. Once the diskette is removed, this door will snap back into position, helping to prevent anything from getting on the magnetic medium and destroying it.
Below is a representation of a 5 1/4" floppy commonly used in 1980's and is generally no longer used today. The 5 1/4" floppy diskette was really floppy (flimsy) when compared to the 3.5" floppy diskette.
floppyd3.gif As you can notice in the above illustration, the 5 1/4" floppy does not have many involved components. First, you will notice the Write protection tab which would be present if the diskette allowed information to be written to it. Placing a piece of tape over the hole or if the hole was not present would make the diskette write protected.
Second, you should notice the large hole in the center of the floppy diskette. This hole allowed the platter within the floppy to be rotated allowing the information to be read from the write access hole.
Third, you should notice the Index hole, this hole was the computer's way of knowing where the starting point of the sector was on the diskette by physically having a hole punched in the film disc within the plastic casing.
Finally, you should notice the write access hole. This is the location which information would be read from as the disc within would rotate. However, because there was no protection like that found on the 3.5" floppy diskette, the 5 1/4" floppy diskette was generally protected by placing it within a protective sleeve.
Hope this helps ya/Let us know ,ok Thank you for using dont for get to Vote.
Jul 20, 2008 | Dell Inspiron 6400 Notebook
Iomega Zip 100MB (31714) External ZIP Drive Logo
115 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
