Question about Apple iPod MA446LL/A MP3 Player
Ipod Video 30 G
My ipod's buttons and wheel are suddenly not working. i tried connecting it to my computer, switching the hold button back and forth, even restoring it to factory settings and leaving it uncharged for a weekend. it still doesn't work. my screen won't turn on unless i switch the hold button. please help.
  • 105 Answers
It sounds as if one of the keys is stuck. You can try pushing each key several times in quick succession, but you will probably need a qualified technician to go any further, as there are no user serviceable parts inside.
Posted on Jul 20, 2007
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
Remove security code
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 20, 2007 | Apple iPod nano
Tip
IPod Nano/Video/Touch Resetting
One day your using your iPod and all of a sudden, boom. It turns off and refuses to work or read by your computer.
You might get the apple logo, but thats where it ends. In this case, theres a few things that can probably bring you device back and kicking.
iPod Nano/Video(Classic)
6th Gen Nano
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
4th and 5th Gen Nano/Classic/Video (CLICK WHEEL VERSION)
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
In case the reset does not work, the alternative is to connect the device in disk mode and restoring it.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. zero77cool.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
This will enable a black/white display. Restore it using iTunes.
If the above doesnt work, then Im afraid its time to repair your device.
Note: images and part of help copyright © 2011 Apple Inc. All rights reserved
on Mar 13, 2011 | Electronics - Others
Restoring my Ipod!
Try resetting the iPod, this usually works.
As follows:
Hope this helps
check out my blog
Mar 13, 2008 | Audio Players & Recorders
I connect Ipod to computer it will not sync
As follows:
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
I plugged my IPOD NANO IN TO THE COMP AND ALL **** SET LOOSE, THE IPOD ASKED FOR A RESTORE, WHICH I CARRIED OUT, I THEN EJECT AND ALLS FINE, THEN I RE ATTACH IPOD AND START INSTALLING 1 OR 2 ALBUMS TO...
As follows:
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
Sync problem
Sep 07, 2007 | Apple iPod nano
Usb problems with 2nd generation ipod
Aug 21, 2007 | Apple iPod nano
Frozen ipod
Aug 02, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
29 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Mohamed Ismail
Mohamed Ismail
woodzowl307
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
