Question about Motorola Mobility KRZR K1 Cellular Phone
How to Fix Cracked LCD Screen?
Can someone post a picture by picture tutorial on how to replace a cracked LCD? hi..so i woke up this morning and noticed there was a crack in my cell phone...its only the outside of my phone but i really want it fixed..is there anywhere in Canada that i can get it fixed and for cheap????
  • 37 Answers
Dear Confused,
Sorry to hear about your phone screen.
There is only one way to make your screen look better, but it will not "fix" the crack. I have done this and sometimes i cannot even tell my screen is still cracked and i didnt have to pay Apple $350 for a new piece of glass.
Here is what you can try:
1. Go to a auto parts store and buy a "Winshield repair kit" for small rock chips that look like a bullseye style chip.
2. CAREFULLY CLEAN THE GLASS WITH ALCOHOL and let dry for 10 minutes. Then heat up the glass of your phone with a hair drier for about 2 minutes so its hot, but not too hot to handle.
3. Then very, very slowly and cautiously, cut the tip of the nipple on the "epoxy/resin" bottle they have in the repair pack and while the phone glass is still hot (you may want to cut the tip of the bottle first, then heat up your phone), gentle squeeze the clear resin into and along the crack in your phones glass....Squeeze the resin directly along the entire length of the crack while attempting to squeeze it INTO THE CRACK...its diffucult, however, the heated glass will **** in the cool resin and actually fill in the crack.
Make sure not to get the resin on the phone or your skin!!!
AND BE PATIENT WHEN applying it.
ALSO, try to do this on a sunny day, because you have to place the glass in direct sunlight, or under a UV light to allow the epoxy/resin to cure. IT WILL NOT WORK UNDER A NORMAL LIGHT BULB. SUNLIGHT Actually works best.
Leave it in the sunlight for at least 1 hour or longer. Then wait another 24hrs before taking a razor blade to scrap off the excess resin that has built up on the glass.
FYI, it the crack to too deep the epoxy will seep thru the glass and this process wont work.
However, if your lucky this should be what your looking for!
Good luck and let me know how it goes!
THanks,
Mark
Posted on Jan 02, 2009
  • 82 Answers
Go see fido, they will send at repair center, usely have a good price !
MY TOSHIBA LCD TV SCREEN IS CRACKED DOES IT HAVE A
Hi Erika,
If your LCD is cracked, you will need to unfortunately replace the entire LCD. Simply putting a screen protector (which is just a thin film) will not stop the crack from getting worse. There is unfortunately no magical way to fix your screen other than simply replacing the LCD panel itself, which is totally doable. Many electronics repair shops can fix your TV pretty easily. In some cases, you can even mail it into Toshiba.
Oct 03, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
Object hit TV screen and now picture looks like a cracked window even though the screen isnt..
Hi, If it looks like a cracked window then it most likely is cracked. this could get expensive to fix if the parts are available
Sep 10, 2010 | Hisense LHD3204US 32 in. LCD HDTV
I have a cracked screen for a Phillips photo frame 9ff2
A new LCD screen can coud about 15 to 20 USD (eBay).
Then see this tutorial: http://www.youtube.com/watch?v=u-5eDINc35s
Good luck
Jun 23, 2010 | Cameras
Hi my tv has been cracked from the inside of it how do i fix it
it depends whats cracked
if the screen is cracked the no fix- screen cost as much as the tv.
if outer frame is cracked then replace frame.
Apr 27, 2010 | Samsung LN37B530 37 in. LCD TV
My screen cracked. I don't know why. It was fine
Hi:
The lcd panel is relatively fragile, and often, the screen can get torqued on if you close the lid with one hand, on the side of the screen, instead of the middle. The good news is that the lcd panels are not too expensive, approx $80, and not to hard to swap out.
Dec 05, 2009 | Toshiba Satellite L305D-S5895 Notebook
Hi well we have a cracked lcd screen and i just
The screen is the most expensive part of the TV, we are talking about $500 and up plus labor.
Oct 29, 2009 | Samsung LN-T4665F 46 in. LCD Television
Remote hit the TV and crakced LCD TV SCreen
There is no way you can fix a broken screen of a LCD set,the only way to fix it is by replacing the complete panel wich will cost more then a new set.
Aug 05, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Help! Cracked LCD display on Canon Rebel xti
Had the same problem myself, I purchased a new lcd from ebay (user name: ProphotoSD). He has tons of factory LCD's, cost around 90$. Please note that if you cracked the clear cover above the lcd that is a separate piece however it wont effect the lcd working (this piece is also replaceable). Then I found a simple tutorial for disassembling the camera body on google. Took me like 25 min, very simple job, just need a very small phillips head screw driver. Hope this helps!
Mar 21, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Cracked Camera
No easy fix. Pressure or impact is the usual cause of a cracked LCD. Try not to get the black stuff on anything....it's pretty toxic! The screen needs to be replaced (assuming there's no other, internal damage). They are usually in the range of $75 US.
Feb 19, 2008 | Nikon COOLPIX S200 Digital Camera
Here is the official service manual from Samsung on how to service and dismantle the phone.
http://www.scribd.com/doc/187562/Samsung-SGHD900-service-manual
The guide with pictures is towards the end of the file.
Jan 31, 2008 | Samsung SGH-D900 Cellular Phone
Motorola Mobility KRZR K1 Cellular Phone Logo
2,592 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
