Question about Panasonic DVD-CV51 Multi-disc DVD Player
Will not read disc
Sometimes when I put in my DVD's some will play then when you change to play another disc it will not read the disc. I have had it in the repair shop twice in the last month. The first time the shop changed the motor,I brought it home and it player for about two weeks,then it started not too read the disc again, I took It back and sat there and showed them what it was doing,I even took my own disc to show them what was happening,while there it happened and they said they had not seen this happen before. When the repaire shop called and said that they had found that the motor they had put in before was bad,and had to put in a new motor,and that when they tried again only one disc failed to read,but when I put the disc in a differant cradle it played. please can you help with a solution too this problem?
    New Friend:
    Problem Solver:
  • 7 Answers
Adjust the trimmer below the lens.
Posted on Mar 17, 2017
SOURCE: DVD-LS5
had same problem here but then i found a soloution might help you helped me
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. , then i spotted that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
it helped plenty of friends hope it helps you
Posted on Dec 12, 2007
SOURCE: DVD player will not read any disc
SAME PROBLEM EXACTLY
Posted on Aug 04, 2008
  • 586 Answers
SOURCE: Panasonic DVD-S35 Player H02 problem
    This problem is related to OPTICAL BLOCK ASSEMBLY. Two things are involved in this situation.
1- sleg motor start malfunctioning.
2- Optical Lens problem.
In both situations you have to replace the OPTICAL LENS BLOCK.
Therefore your DVD need lens replacement. And it would work fine again.
Thanks for using fixya.
Posted on May 31, 2009
TEKUSER
  • 86 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
  • 15 Answers
SOURCE: dvd player not recognising any discs
Did You Try Taking off The Cover And Cleaning The lens With Rubbing ahocal
Posted on Jul 18, 2009
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 14, 2012 | Sony Televison & Video
Need help working out what is wrong with my DVD player
If the dvd player is old it maybe the laser pickup lens dirty you can clean the lens but you have to be very very careful if you do try put no pressure on the lens
get a cotton bud/q-tip and clean the lens very gently you will not see much dirt but lite cleaning will remove a film from the lens
I hope this helps
Feb 21, 2008 | Panasonic DVD-F87 Multi-disc DVD Player
Dvd sometimes reads error
If this problem occurs only at this dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | Samsung HT-Q20 Theater System
After inserting a disc the dvd goes into the machine, the menue box on the tv screen changes to loading, stays on loading for a short time then pushes the dvd back out. The machine never changes to play.
the dvd player is unable to read the disc. either the disc is scratched and cannot be read or the player needs cleaning. cleaning discs are available pretty much anywhere. sometimes simply blowing into the area when the tray is open can temporarily fix the problem.
Nov 17, 2009 | Mintek DTV-263 26 in. LCD Television
Player won't play any disc now
Time to look inside the dvd player. try readjusting the variable trimmer under the laser lens of the dvd player assembly. It is usually located under the lens assembly. try to adjust the lens at every 1 degree angle up to +/-5deg. sometimes it can be done. if not. time to change for new lens. damage lens is caused by using pirated DVDs or bad disc as the lens is trying to read the data on the cd.
guest.
Mar 13, 2009 | JVC DR-MV7 DVD Recorder/VCR
DVD Player reads Unreliably
your dvd needs to be serviced have a tech look at it, if that does not fix your problem replace your dvd for another one. good luck
Jan 06, 2008 | Televison & Video
Akai dvd/vhs/tv combo
Try and get a Lens Cleaning disc and put it into the DVD Player side and wait until it's done.
Jan 05, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
DVD player won't work
same problem as above===put disc in and get no disc or error disc also mine will read then just stop
Dec 30, 2007 | RCA DRC6300N DVD Player/VCR
WHEN I RECORD A DVD IN MY MWR 10D6 DVD RECORDER IT IS NOT ABLE TO BE PLAYED IN MY OTHER DVD PLAYER WHICH IS A TOSHIBA. WHEN YOU PUT THE DVD IN IT ALWAYS SAYS PLEASE CHECK DISK. THIS ONLY HAPPENS WITH DVD'S...
When you burn your DVD the disc has to go thru a FINALIISATION process before it can be used on other DVD players. Sounds like either your recorder hasn't run the finalisation or it doesnt do one, in which case your DVD's wont work on another player. Check thru your menu's for a FINALISATION option and make sure you run it.
Marty.
Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Check disc
Is the surface or your disk smudged or damaged? If not, try a lens cleaner CD or kit and see if the problem goes away. If they are DVD Rs or something similar(DVD-RAM, DVD+R, ETC) the player may not be able to play that particular format, and you should double check the instruction manual to see what types of disks can be read.
Nov 08, 2007 | Sony DVP-FX810 Portable DVD Player
Panasonic DVD-CV51 Multi-disc DVD Player Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
