Question about Bulldog& Remote Alarm System With 1-wire Hookup
Where may I obtain a replacement remote and directions for Bull
Dog remote auto starter/alarm? I have searched and cannot find anywhere through google or web. It is a unit dated 2005/06? Please advise if you can help
    President:
  • 1,990 Answers
Go to www.BulldogSecurity.com and do a little looking. I had the Same Problem with Mine and got mine through their Website. They will tell you also how to Program the New Remote to match your Starter. Let me Know how it Goes!
Posted on Jan 02, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do I set the alarm on my Nelsonic NLC690 alarm clock radio to 94.9 the bull?
Set the radio so you can hear 94.9. Set the Alarm Time, set wake by radio as opposed to alarm.
nelsonic clock radio nlc 690 manual Google Search
General info on that type here
How To Set TIME ALARM CLOCK of VINTAGE Old LLOYD J375 771A RADIO AM FM...
And a basic more modern one like yours. You can get yours from Walmart, so you could go in and ask for a photocopy of the instructions.
http://jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf
Aug 15, 2017 | The Audio Players & Recorders
1997 Big Dog Vintage Classic at Sturgis, SD this weekend, just quit ! He (Art/husband) is out there looking for the problem..12 volt from battery to turn on switch Nothing after that In linefuse loca
Hi, Deborah and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter control circuit, relay, or solenoid faulty.
11. Main fuse or circuit breaker may be blown or faulty.
12. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
13. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
What to do When Your Motorcycle Won Start
TROUBLE SHOOTING
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
Big Dog manual 2005 all models pdf
Aug 15, 2016 | Motorcycles
I have a blaupunkt 39" tv the remote has stopped working but I do have a ofa urc 11-1660 r01 will it work with my tv o and I can not find the instructions for the remote
If you do a google search or a worldwide search on Ebay you might find a replacement somewhere. I obtained a replacement Grundig pattern control from Germany for a fifteen year old set. You might be lucky.
Sorry if this does not directly answer your question but it is an alternative possibility particularly if the remote you do have is unusable.
Good Luck
May 26, 2015 | Blaupunkt Televison & Video
I bought a Spy brand one-way car alarm/remote start for my wife's 09 Camry. Everything is installed, and works except for the remote start.
Installations of this nature are usually reserved for professionals. However, get out your installation manual. You will also need two single pulse double throw relays and some diodes. First you will need to locate the ground when running.This wire might be labeled " (-) third ignition". The first relay for the starter will be wired like so: starter wire to 86, fused 12 volts to 87, 30 out to vehicle second starter wire, 85 to ground when running. The second relay will be wired 86 to vehicle ignition, 87 to fused 12 volt, 30 out to second ignition, and 85 to ground when running.
Jan 22, 2013 | Brand Remote Start/keyless/car Alarm Very...
So the big one with the screen on me took a **** awhile back. so i was only using the black one, but now the dog ate it? If i use the key the alarm goes off. HOW DO I TAKE THIS OUT MY CAR?
Hello my name is Israel and I will help you. You can still use the alarm but you will have to do a couple of steps. Enter the vehicle. The alarm will sound. Insert key and turn to the 'run" position. Push or set the override button and alarm will turn off. The remote should be easy enought to replace. If you want to replace it, let me know and I will try my best to get a remote for you. Good Luck.
Feb 19, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
I have installed a bull dog remote starter on my 2001 grand am. everything starts fine but car wont shut off with the key.
This would only happen if you did not install the brake cut off switch. You will be able to shut the car off with the key after 15 minutes or with the remote.
Oct 31, 2009 | Remote Starter with Keyless Entry
96% installed when told files\hp\photosmartessential.msi...
try to download drivers directly from site www.hp.com. May be your disk was broken from scratches.
Mar 05, 2009 | HP PSC 1410v All-in-One Printer
Need instruction manual for Logitech Harmony 525 remote control
Hi there, You can download the manual at the following location:
http://images.harmonyremote.com/EasyZapper/Downloads/UserManual/525/enu/525_UserManual.pdf
regards,
Craig.
Nov 27, 2008 | Logitech Harmony 525 LCD Remote Control
Bulldog& Remote Alarm System With 1-wire Hookup Logo
126 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
