Question about Sony PlayStation 2 (PS2) Console
Recording button can't be pushed down any longer
Recorder fell from kitchen table on tiles - everything ( radio/tapes ) still worked after that fall - all was fine, except the button for recording ( the button with the red dot ) it resists to get pressed down.
It moves like 1 millimeter or so down along with the tape play button when I attempt to press the recording button down
I also can see the millimeter down movement behind the open tape lit, the whole metal mechanism goes down 1 millimeter along with the attempt pressing the recording button down -
So I can't record, can't get the recording button down into the
" click in - stay - record position "
So no recording is possible any longer.
  • 26 Answers
Oh, I see, you're talking about a cassette player, You are in the wrong section if that's what you're talking about. If thats the case, then the impact of the fall must have jammed it . and you may have to go in and correct it by freeing it up
Posted on May 05, 2010
    Problem Solver:
  • 13 Answers
1. PlayStation 2 systems do not handle tapes, but CDs and DVDs. No wonder you have broken it if you inserted a tape in it.
2. There is no radio in a PlayStation 2 system.
3. On a PlayStation 2 system, the button with a red dot on it is the power button, and it turns green when the power is on.
4. You cannot record, especially not on tapes, with a PlayStation 2 system.
5. You usually don't play a PlayStation 2 in the kitchen, but in the living room since it's meant to be plugged in your TV.
Here's the diagnostic : you do not own a PlayStation 2 system.
You have been ripped off by whoever sold you this piece of **** under the name of "PlayStation 2 system".
Posted on Jan 03, 2009
Recorder button does not go down. . Is there anyone who knows how to fix this problem
There is an interlock that prevents accidental recording. You may have to press PLAY and RECORD at the same time.
Jan 01, 2015 | Sony Tcm939 Table-top Tape Cassette...
How do I turn my turn table on. POWER button is on. What other button do I push. I have phono, mono/st, cd, tape, tuner??
Phono button is turntable selector. May be the turntable switches on when you move the arm to the edge of the record.
Dec 17, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
VCR ejects when asked to record
there is a plastic clip that pushes against the tape to let it know its recordable it is at the bottom of the vcr in the front and is probably broken or came loose repair it or tape the button down but be careful taping the button down will let it record on all tapes
Jan 03, 2010 | Televison & Video
Record button does not work I press the record button and ejects the tape
The sensor switch which pushes against the record tab on the tape is either bent out of shape, or broken. Therefore the video recorder thinks that the tape you put in is a pre-recorded or protected tape, thus ejects it.
Dec 21, 2009 | Emerson Televison & Video
Record button is stuck and cannot be pushed down.
Make sure the tape is not protected or broken tap on bottom of tape
Dec 08, 2009 | Sony Pressman TCM-929 Desktop Cassette...
How do I tape to tape
you mean to record?first,you must connect the other unit (if you are using two cassette)by using rca plug or earphone plugs.insert the plugs to audio in or aux(this is the unit that will record).if the other unit doesn't have the output audio,use the earphone out instead.time to record.the recorder must be set to tape/aux,(if you are using a unit with radio setting).then,push the play and record button at the same time.don't forget to put in the blank tape ok.then push play to the unit that you want to be recorded.the square symbol is for stop.the arrows pointing left ,rewind.pointing right, forward.the big arrow pointing right is the play and the button next to it is the record button.
May 14, 2009 | Panasonic RX-D29 Radio/Cassette/CD Boombox
Recording on tape deck
I have not "solved" the problem. I'm simply assuming that the built-in microphone does not work. I CAN record radio on to a tape and a CD onto a tape. I just cannot record my voice onto a tape. I'm just chalking it up to a faulty microphone.
No, I do not want a plan, thank you.
Mar 31, 2008 | GPX BCD2805 Radio/Cassette/CD Boombox
Pv-dv53d
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Sony PlayStation 2 (PS2) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
