CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-5
You can try this solution:
Issue: ERROR LCD: WASTE INK NEAR FULL
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
You can also follow this link to the MP130 page on canon's Web site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10442 to download a user guides, drivers, views specs, as well as receive support and service. To search Canon's knowledge base for a solution, you need to type "waste ink absorber" in the text box on the Support & Service tab. Click Search then click ERROR LCD: WASTE INK NEAR FULL. You will be given 4 possible solutions. The one that I provided above is #2.
You can also download the user guide (if this is a windows system, you will download the user guide from the Software & Service tab. Click that tab then select your operating system. Scroll down to the table labeled Guides and Manuals then scroll down to find the Pixma MP130 User's Guide and click on the (.exe) file name. The file is compressed and by running it on your system, the guide will be decompressed and installed.
Hopefully this solution assists you with the waste ink absorber issue as well as any other issues or information that you need for this printer.
Thanks for using Fixya!
Please share your experience by rating this solution.
printer after refills put in went to E5hat do i do
every time I print I get the "waste ink absorber is almost full" message, I can still print if I press the start button on the printer but I'm worried that someday it will just refuse. Is it possible to replave or empty the ink absorber?
i just refill the ink cartrages of my pixma 470 but still showing the ink has run out. why i can't use the printer eventhough i just want to use the scanner?tnk. DSL
