Question about Kirby Ultimate G Bagged Upright Vacuum
Front drive belt
The drive belt has come off.
  • 328 Answers
Copy and paste the following link:
http://uk.youtube.com/watch?v=At7tqnjD-Kc
Posted on Jan 02, 2009
How do I change the belt on my Hoover U6311-930?
At the front 2 screws hold on the front cover if you remove them you will be able to access the brush roll and belt
Feb 27, 2011 | Hoover U6311-930 Power Drive Bagged...
The belt came off. How do I get it back on
The front square trim peice actuallys turns to open up to replace the belt onto the drive spindle
Jun 28, 2010 | Kirby Generation 3 Bagged Upright Vacuum
The brushroll won't spin
You need to replace the drive belt. You can get replacement belts here:
Replacement Vacuum Belts
Feb 07, 2010 | Vacuums
Vac is supposed to have auto height adjustment but it doesn't
If the brush isn't working then its maybe because the drive belt is broken. Locate cross head screws on top of the hood of the Eureka vac (two at the front usually and one below the duster or at the left hand side if looking at the vacuum from the front) Once the screws are undone check to see the drive belt is intact. If its not then replace with a new one and check at the same time that the roller brush is properly put in. If the drive belt is ok then check the brush roll - something may have jammed it if it isnt the belt. Dont forget to rate please.
Mar 20, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt
Hi.
Your Dyson will probably have A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left front side of machine looking from the front & rotates to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
May 26, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
May 13, 2008 | Fantom Vacums Lighting Canister Vacuum
Engaging belt on Kirby G5
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. The hook stretches the belt so that it can fit over the fan drive.
Next, place the two "feet" of the powerhead onto the "perch" on the front of the kirby....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
then turn the belt lever from off to on.
the G5 should have a light on the powerhead that comes on (green) if the belt is spinning the brushes. That will let you know if you've got it on correctly.
Dec 24, 2007 | Vacuums
Kirby g4
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby and you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. (OFF position) The hook stretches the belt so that it can fit over the fan driveshaft (its the finger looking thing that sticks out of the front of the kirby when the powerhead is removed.)
Next, place the two "feet" of the powerhead onto the "perch" located on the front of the kirby (under the driveshaft opening)....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
Now spin the knob on the front of the kirby from off to on. This releases the belt from that hook in the powerhead so it can rest on the driveshaft. Off means the belt is off of the drive shaft and the brushes won't spin. On means the belt is on the driveshaft and the brushes will be spinning. But remember, the belt has to be stretched open on that hook inside the power head BEFORE the powerhead is placed on the front of the kirby. Otherwise the belt won't be connected to the spinning driveshaft, and the brushes won't spin
Dec 08, 2007 | Vacuums
How to put the belt on ?
Dec 06, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
27 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
