Troubleshooting Cabrio, Bravos, & Oasis Washer Problems
Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests '
Tips & Tricks
Error Codes
LF '
Ld '
uL '
oL '
Sd '
lid '
Po '
HC '
dL '
dU '
F1 '
F2 '
F30 '
F32 '
F40 '
F41 '
F50 '
F51 '
F52 '
F53 '
F54 '
F70 '
F71 '
F72 '
F80 '
F81 '
F82 '
F83 '
F84 '
F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea.
(Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the
pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display.
Washer Diagnostic Modes and Tests
"Po" Pump Out (Lid Opened)
Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched
This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85)
Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code.
"Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32)
Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the
KEEP GETTING OL CODE. HOW DO YOU MAKE IT STOP
Ol code comes on with very very light load. OL stands for "over load" Washer has had Whirlpool trying to fix for 6 weeks and 5 repairmen! They tried new motor and now replacing tub and basket and filters??
OL stands for over load!!
I just had one of these today and the Center Tub Bearing had seized. Don't Know if the problem you have is similar
