Question about RIM BlackBerry Curve 8310 Smartphone
8310 won't charge
My BB 8310 curve will not charge through the power point charger or the usb cable. i plug it in and a picture of a battery with a lightening bolt through it comes on the screen and stays there until i take the battery out. i've taken the battery and sim card out but it still wont charge. PLEASE HELP :)
  • yvette hernadez Jan 03, 2009
    Im having the same problem. its completely dead.. no charge, Ive plugged it in, and a pic of a battery with a lightening bolt comes on the screen and thats it.. help...? I need my blackberry for my job..
    help.. thanks.
  • robledok Mar 15, 2009
    Error message: USB charging current is not sufficient. Verify that your handheld is connected to a powered USB charging source and that the proper USB driver is installed.
    Question: Should I do something with the Blackberry maybe in options?
My phone was doing the same thing. I woke up in the morning to see that is wasn't charging from any outlet or my USB.
I instead concentrated on the USB opening on my phone, and realized that one of the pins was so ever slightly moved up. I took a safetly pin and gently kept bending it back down. Now it charges. Good luck and hope that helps! Just something different from the warranty/flashthrow away solution.
KP
Posted on Feb 27, 2009
I did what joekak911 posted and now it works fine.
Posted on Sep 05, 2009
My 8310 done the exact same thing, i sent it off back for repair and when it came back a letter said that the solution for it was to install the operating system again, due to a software error.
Try backing up all of your essential data (phone numbers, photos, messages) taking the memory card and sim card out and plugging it into a PC and using desktop manager to Re install a new operating system (you can download software off of blackberrys official site)
Alternativly if its still within warranty and you cant do it, or you can do without it for a week or two, then send it back to your Network Providor. They have to repair it By law if its within the Guarantee.
Hope this helps
Louis Brown.
Posted on Jan 23, 2009
  • dpogue4 Jul 28, 2011
    I changed my cord for charging, and all was okay. It may be a pin contact on your cable is causing a surge, or cross wiring leading to surge.
My Blackberry refuses to Start Up
There is an issue with your firmware. You will need to do is:
1. Unplug BB from PC.
2. Launch the "Application Loader" like you were going to install something.
3. While the app loader is attempting to connect to the BB, plug the USB cable into the BB.
Apr 01, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
I have a bb 8320 and when i plug it into the wall it charges but when i plug it into my laptop nothing happens why is that?
If your regular charger is working in the wall, it sounds like the USB cord that you are using with your computer isn't a "charging" USB. I don't think you are having a malfunction with your BB.
Feb 15, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
My usb port is damaged on my blackberry can not charge it how do I charge the battery? I cant charge it via the usb port which is needed for almost everything. is there another way to charge my blackberry...
The only thing you can do is use another BB to charge up the battery, and then swap batteries. Someone usually has a broken BB (screen dark, sound stopped working etc) which they will give you for free..
Jan 01, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
My blackberry curve 8310 was dead this morning when I woke up. I plugged it to the charger and charged the battery. The phone will not turn on. It tries to but will not boot up. I switched out the battery...
I hope battery is working fine,so try connecting this phone using USB cable to computer, and check wheather computer is recognising your device.still if its not working then you can go to nearest service center.
Oct 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
Battery picture with line throuhgh
Sounds like the battery has failed. Replace it on Ebay for a new cheaper battery than at AT&T.
Aug 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
My BB 8320 will not power up
try turning it on with the battery removed while it is connected to the charger.
if it turns on fine then, it's a battery issue. if it still doesn't come on, i would recommend reinstalling the device software with the desktop manager software. both are available on blackberry.com
Jul 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. A new battery was tried and the problem still exists.
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in to cell store.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Power surge on hub port
I am having to send my wife's curve out for repair today as it seems that the very fine connections made to the circuit board from the power port have come away. This port seems to be very fragile, and poorly designed IMHO given that it has to be used so frequently.
Sep 03, 2008 | RIM BlackBerry Curve 8310 Smartphone
The battery life gor my blackberry curve 8310 is simply horrible!!
I have a Curve too and my battery life has never been longer than 7 hours, I have to bring my charger to work to make it through the day. I am on my second battery too and no improvement. I have also taken off any programs that may **** battery life and its not helping.
Jul 26, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
3,266 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
