Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Broken Door Lock Motor, part no longer available
I have a KitchenAid convection oven model KEBN107YBL0 which goes into CLEAN mode no matter what I set the controls on  - i.e. Bake, Roast, etc.  A repair Tech came out and said it's because the Door Lock motor is broken -- when you set it to CLEAN, the door does not lock and the "Lock" light on the door panel does not come on.  Unfortunately, the door lock motor, part #4367561 is no longer made and I've contacted several obsolete parts distributors with no success.  I thought I'd found it on the internet at A-1Appliance.com, but they just emailed me saying they'd made an error and they don't have the part either.  What can I do, aside from buying a new oven?  Someone suggested that I try to find someone who repairs small motors, but so far I have not succeeded in that, either.  I'm in the LA area.
  • wwinks Jan 02, 2009
    Actually, I have more info. I just tested the CLEAN cycle and it worked just fine. The door locked after the temp got high enough. So the Tech's diagnosis that I need a new Door Lock Motor was incorrect. What IS the problem, though, is that no matter what mode the oven is in -- including OFF -- if I press the Start button it goes into CLEAN mode for 3 hours. (In the OFF position it does not actually start, it just displays the CLEAN symbol + 3:00 in the panel.) The oven was originally purchased in 93. Could it be a problem with the START button?
    Master:
  • 416 Answers
  • KitchenAid Master
  • 19,396 Answers
"if I press the Start button it goes into CLEAN mode for 3 hours."
There are several faults that can cause the oven to behave erratically and to get stuck in clean mode.
The more likely is a defective control board or a loss wiring, sometimes wiring and control board get damaged when the cleaning cycle takes too long, because of the high temperature.
Faulty keypad usually returns error message, but this is also possible.
A faulty sensor probe, even if this gives you normally an error message , the temp sensor should be tested with a multimeter.
I suggest to inspect wirings and board, and eventually test probe, that must return about 1100 ohms reading.
Then test and eventually replace the board.
All jobs must be done by qualified personell.
Enter model number here to find parts and schematics.
Posted on Jan 02, 2009
    Sergeant:
  • 311 Answers
Well it goes into clean no matter what because the clean mechanisum leaver is stuck in that position,so its always telling the stove to clean.if you can get the repair man to move it so the clean micro switch is not depressed ,voltage will then pass to regular opperation.in Gods servive,tom
  • 916 Answers
First I would check the thermal fuse and if it is a newer oven call KitchenAid. They should send a tech to replace the part for free as it is a well known problem with there ovens self cleaning feature burning the thermal fuse.
    Genius:
  • 3,422 Answers
HI,
You can get this repaired from www.reapairclinic.com
They will fix this issue.
  • Priya darshan Jan 02, 2009
    They also give free repair estimates.Here is the contact no. 800-269-2609
    If you need anymore help let me know.
    Repairclinic will have the part which you require.
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
This oven has a motor driven electric door lock located immediately behind the control panel. When I attempted to put it in the clean mode, the 4 hour timer came on as it should, the lock door icon started...
Sorry to read about your problem, I hope this helps you out.
you can remove the motor, put 120 volts on it, if it does not work, their is your problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Ovens
Can't unlock oven door
Put the oven in self clean mode, it will lock the oven, once the self clean mode has started turn the self clean mode off, give it a second and the oven should turn off. Same thing just happened to me and it worked.
Dec 24, 2010 | KitchenAid Ovens
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Kitchenaid Convection oven
F5
E0
E1
DOOR AND LATCH SWITCH DO NOT AGREE
DOOR LATCH NOT OPERATING.
PROCEDURE: Before proceeding, press OFF, OFF, START to enter
the Diagnostic mode and verify the error codes.
TO VERIFY DOOR SWITCH:
A. While in diagnostics, open the oven door. The second digit on the clock display
should toggle between “1” and “0” as the door opens and closes. When door is
closed display should show “1”, when the door is open display should show “0”.
If the second digit on the clock display did not toggle, go to step B.
If the digit did not toggle after replacing the door switch, go to step D.
If the digit did not toggle after replacing the door switch harness, go to step F.
B. Unplug oven or disconnect power.
C. Replace door switch. (If door switch is integral to the door latch motor
assembly, replace the entire door/latch motor assembly). Go to step H.
D. Unplug oven or disconnect power.
E. Check the integrity of the harness wires and connections between the
appliance manager and the door/latch assembly. Ensure there are no shorted
or pinched wires.
If the wiring harness is pinched or damaged, replace the door switch harness.
Go to step H.
If wiring harness is good, go to step H.
F. Unplug oven or disconnect power.
G. Replace appliance manager. Go to step H.
H. Replace all parts and panels before operating.
I. Plug in oven or reconnect power.
J. Press OFF, OFF, START to reenter the Diagnostic mode and complete checks.
Repeat step A.try this lighting may have knocked either the door switch or latch motor out
Mar 30, 2008 | KitchenAid KEWD105HSS Oven
Frigidaire Electric oven model # GLEB27S7C
If you unplug the range and remove the lower rear cover on your left side you should see the motor with 2 switch's on it. There are 3 possibilitys with it. One of the switch's on the assembly is not working or the light switch for the door is not good. You also can disconect the lead to the motor and connect a power cord to it and that will unlock the door so you can check the dor switch also. if you do not feel comfortable powering up the lock motor then you should call a repair man. But one of the switches is not letting the computer know the dor is locked.
Jul 24, 2007 | Frigidaire GLEB27S7A Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
20 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
