Question about Toshiba 42HL196 42 in. LCD HDTV
Faint black lines running vertically
I have a 42 " Toshiba 42HL196 TV that is 2 years old. I have started to get a faint dark line in the middle of the TV and another near the right side. It is visible on all inputs and cannot be fixed by adjusting picture settings or unplugging etc.Is there an easy fix for this problem as my TV is now off warranty and I do not want to dump a bunch of money into it. Is this a common problem?
any thoughts / advice would be greatly appreciated.
  • 5 more comments
  • bandm Jan 02, 2009
    yes tried that with no success.
  • cnhetzler Jan 09, 2009
    i to have the same problem. i have the extended warranty but store is giving me the runaround.even their service tech told us he has the same model with the same problem and there is no fix.
  • Anonymous Feb 25, 2009
    Same problem. I have Best Buy extended warranty though. We will see
  • Anonymous Mar 05, 2009
    Vertical line in center of screen started 2 weeks ago. Tried unplugging it and the line was fainter but still there. Researching the internet and this seems to be a common problem with no solution yet. Looks like Toshiba and some stores are just ignoring the problem.
  • seacrow Apr 04, 2009
    I have somewhat the same problem but not down the center on either side of screen where the border is for non wide screen I can fainltly see them when i switch to wide screen really bad if the picture is a bright picture
  • Anonymous Apr 15, 2009
    Same here, it appears to be getting worse down both sides of the screen various widths. Almost looks like water stains....but absolutely not possible.
  • shelby29 Apr 30, 2009
    I have same problem. Sometimes it center line and the right side line are more visible , depending on what color is on the screen. The lines are very noticeable when watching golf. I called the service center that Toshiba recommeneded and they said the entire panel would need to be replaced so if it wasn't under extended warranty, just live with it.
I had those too, and I sort of still have them. I found the best way to clear them up is to set your cable box to "stretch", so that it stretches non wide-screen (analog) broadcasts to the full length. Those lines show up at the transition from the picture to the black on 4:3 shows. The lines for me eventually became so faint they were barely visible.
Posted on Jan 11, 2010
Did you try unplugging everything and resetting your cable box. then plugging it back in,
i got some faint boxes yesterday and that did the trick
Posted on Jan 02, 2009
I have an Olevia 242TFHD LCD tv, and there is a faint black line running vertically from top to bottom on the right hand side. There are also occassional red and blue lines running horizontally. The tv is...
You may have failing T-CON board. you will get more lines as time goes by. Try cooling it with freeze spray for electronics troubleshooting.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 02, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Regza 42'' LCD Toshiba LCD
lines are bad panel, sorry
Aug 11, 2009 | Televison & Video
Black vertical bands in screen. Started as faint shodows now dark
Replace the ribbin cables that connects to the lcd panel. don't have part #
Jun 10, 2009 | Sylvania 6626LG 26 in. LCD Television
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
May 03, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vertical black line down centre of screen
I have same problem. Toshiba 42' hl196 purchased 4/07 line appeared 1 year and 9 months researched on Toshiba thread. Bad LCD screen. Repair cost more than tv-have to replace lcd screen. I didn't get the extended warranty. If still under warranty get hold of toshiba. Lot of people having same problem. Should get aclass action lawsuit started selling defective LCD screens. Kathy in Cleveland,OH
Dec 15, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Vertical lines in my laptop screen
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Faint Black Line down the middle of TV
Sounds like it could be pixel problems or board problems, this depend on the location. Most are mostly to the left or right, or going across the set to the upper or more to the lower side. For more info visit ctechnicians.com
Jan 06, 2008 | Sharp LC-37D7U 37 in. HDTV LCD Television
Toshiba 42HL196 42 in. LCD HDTV Logo
791 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
