Question about Philips SA5125/37 MP3 Player
I get nothing from my player.
The unit will not turn on and nothing happens when connected via USB to my computer. I've had it for 1 yr and it has not worked for a couple months.
I just had this problem again this morning and solved it in about a minute. For my player all I do is hold the "on" button down for about one minute (maybe a minute and a half) then try to turn it on normally a few seconds later. It has always solved my problem!
Posted on Jan 02, 2009
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
When i turn on my prs 300, the screen flickers and the light on top is yellow. when its done trying to turn on the light flashes a few times and thats it.. i've tryed several computers and they cant...
Hi jmjohnson198!
1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
2. Hit the reset button for 3 seconds.
3. The red steady light should come on, if not, try the reset again while the unit is connected
4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
5. Disconnect the reader and see if operational.
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 16, 2011 | Sony Reader Pocket PRS-300
Battery level shows about half. Charging arrow doesn't show.
Try a different usb cable or mabey the actual usb port
Jul 09, 2009 | SanDisk Sansa e250 MP3 Player
I have connected to my computer but nothing happens.
I presume that you are using the docking unit, so plug it into a usb with the tomtom turned off, then when you turn it on it should boot up the tomtom home prog.
If that doesn't work, remove any existing tomtom home prog from your PC and try again.
Download tomtom home from your CD or from the website.
If you have aquired the unit second hand it may be blocked due to security reasons.
The only way to sort it then is to mail TomTom and give them your serial number and an explanation !
Apr 23, 2009 | Tomtom GO GPS Receiver
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
MWZ-S615F will not charge or connect
I'm sure it's the cable that's not functioning properly. Mine started doing the same thing and after wiggling and adjusting the cable inside the MP3 itself, the computer finally recognized it and I was free to charge and add music. Also you can try to connect it to a different USB port on your computer. The beeps however are news to me, unless I just never noticed. One piece of advice is to never let the MP3 battery die, because after I let it happen mine began to experience more severe problems.
Oct 15, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Connects to the computer but wont turn on
i have the same problem to!! what a heap of ****!
Oct 11, 2008 | Samsung YP-K3 MP3 Player
Sony nwz-S515
Try adjust the USB cable and/or switch which USB port it's connected to on your computer. Also just patiently let the player sit and try not to perform any other actions on the computer. When mine did this, I opened Media Player, wiggled the USB cable and waited. Eventually it connected and worked correctly.
Sep 28, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Sync
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Oct 14, 2007 | iLO (2 GB) MP3 Player
Philips SA5125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
