Question about Refrigerators
Refridgerator cooling air flow direction.
Kenmore side by side refridgerator12 years old, fitted with a new GE fan motor draws air in from the front of the fridge and out (hot/warm) at the back of the firdge through the cardboard grill. Is this the right direction of flow or does it matter?
  • Harold White Jan 02, 2009
    Thanks for your answer.
    Here's wishing you a Happy New Year.
    Truckpump
  • 242 Answers
Hello , this is the correct direction for airflow and its why there is always dust buildup on the cardboard panel. Let me know if you have any other questions.
Phil
Posted on Jan 02, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Tip
Clean and cool laptops are happy laptops...
Many laptop hardware system failures can be directly attributed to excessive heat build up on vital internal components on the main board. After a couple years of fairly regular use dirt, hair, and dust will build up on the heat sync gradually cutting off all air flow. (btw you can have a spotless home or office and this is still true) You may hear the CPU fan staying on more frequently and working harder and harder.
Many folks purchase base fans which run on USB... but my philosophy is that if you think you need one, then cooling system probably needs to be serviced. (and drawing more current out of the USB can just add to power demands)
The easiest way for a user to prevent this is to service it starting when it's only a few months old. We want to back flow it with compressed air. Flip your laptop over. Locate the CPU cooling fan and air intake. Using a paper clip lock the fan through the intake so that we don't spin it at a zillion RPM. Using compressed air blow into the fan outlet. Should be at the fan area on the side or back. Remove paper clip making sure fan spins free.
If your laptop is more than a couple years old and you suspect low flow due to restrictive heat sync. You may want to have a qualified technician service it. When servicing laptops more than a couple years old I always disassemble them completely. If clogged severely and you try to back flow it, you can lock the fan up with debris causing fan failure.
Always keep air intake on bottom clear. Do not use directly on bed, carpet, sofa, or any restrictive area (also with contaminates) without a flat hard surface to maintain constant air flow.
May your laptop stay cool and happy for years!
on Jun 06, 2014 | Computers & Internet
Can a refridgerator fit snug or does it have to have air flow?
In my many years of fixing appliances many people have asked me this question and yes it can fit snug if you make holes so it can draw air into the side of the cabinet if your fridge cannot get air to cool the compressor down you will cut the life expectancy of your compressor down drasticly. As an option i find it is alot less costly to drill a couple holes down the bottom of the cabinetry or on your flooring behind the fridge then replacing a whole compressor hope this helps
May 16, 2010 | Refrigerators
My freezer is fine, my refridgerator quit cooling, what can I do? I don't see any frost but I have not looked in the back of the freezer yet. I've lost everything in the refriderator side. I'm not sure of...
Probably the 'Chinese fan syndrome.'
The freezer compartment is (logically) favored for cooling. There is a fan, normally between the back of the freezer compartment and the outside sheet metal that circulates the cooled air from the hidden coils to the refrigerator compartment.
Try this: When you hear the compressor is running, look for vents in the back of the refrigerator side and hold some wet fingers in front of these. Under normal circumstances, there should be an easily noticeable flow of air coming from these vents that represents the fridge's share of the cooled air. If there is none or is very little flow, the fan has either slowed (sticky sleeve bearings) or the fan has stopped completely.
This isn't a dangerous problem since all modern electric motors are 'impedance protected' meaning that if the motor cannot turn, it still will not get any more than hot, it won't catch fire as they once would.
Sears carries or will order a vast number of parts for appliances other than Kenmore and has thousands of illustrated breakdowns of these in their library.
Use the link below to go to their parts department and enter your model number to see if they have your KitchenAid model in their library.
If they do, you will have a line drawing illustration of your appliance which you can use to see how to access and replace the fan yourself.
Sears parts
If it appears too difficult for DIY, you may be able to at least order the part to avoid the markup of the service company that comes to swap the fans out.
Apr 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Kenmore refrigerator with bottom freezer. freezer works,refrig does not. Can you help me find the problem .Also, bar between the upper doors gets real hot.
I had this problem. The Evaporator fan in the freezer was working but no air would be circulated from the freezer into the refridgerator. To test this you open the door of the freezer, and depress the door button(s) of the upper refridgerator doors so that the light extinqueshes in the refridgerator. This will engage the evaporator fan in the freezer. You can check to see if air is venting from the freezer into the refridgerator by feeling the holes at the top most part of the multi-air flow channel in the refridgerator. If air is comming out when the freezer door is open, close the freezer door and feel if air has stopped. If you have kept the upper door buttons pushed in on the refridgerator and now have the freezer door closed, you should still hear the fan running, but may have not air flow with the freezer door closed. The cause of this is the air return channel from the refridgerator to the freezer is either frozen or clogged. My return-air channel was not frozen but clogged by a residue from something that spilled inside of the bottom of the refridgerator. The return-air channel has two vents in the rear-bottom of the refridgerator that exit into the freezer behind the evaporator (cooling coils). You can't see it even if the back interior panel is removed from the freezer compartment.
The bottom line here is that if air is prevented from moving from the refridgerator, back down to the freezer, then your refridgerator will not cool, but your freezer will work just fine. You will not need to replace the fan, unless the fan is not functioning. You may need to check the dampener, to ensure that your multi-air flow channel is open - (allowing air to come into the refridgerator). The multi-air flow channel is easy to remove once all of the shelves are removed from your refridgerator. Only 2 screws holding it in (securing the center rack top and bottom). The top screw is located behind a small plastic cover that can be removed.
That's what worked for me.
Jan 12, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The freezer is cold, but the fridge stays around 40 degrees, and the unit keeps running continuously
The evaporator fan motor may be about to seize and is running to slowly to cool the fridge, cost about ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Available from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Nov 10, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
My freezer is working but my fridge is not. GE its a side by side fridge with a freezer drawer.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is usually the evaporator fan motor ($30).
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and doesn't spin backward drawing air from the freezer area..
Nov 10, 2009 | Hoover HCA331FFK
Freezer side working fine but refrigerator side not cooling at all. Has been like this for a week or so.
Nov 09, 2009 | Jenn-Air JCD2389G Side by Side...
Refridgerator is not cooling. I hear the fan but there is no air flow
Ok when you say you hear the fan and no air flow, am I to understrand if you put your hands in front of the vents in your freezer no air comes out ?
The noise you are probably hearing is the compressor motor running (a humming sound) - you may have a bad evap fan - you will need to have your system checked and check the evaporator fan motor - if this is not working there will not be any cooling and air flow. they might also want to check your control board.
Aug 23, 2009 | Whirlpool GS2SHEXN Side by Side...
Hot high side assembly and at the front door section
Replaced the GE fan motor which seems to have solved the problem.
Dec 28, 2008 | Kenmore Refrigerators
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
