Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Lights, Fan, Compressor all seem to work. Compressor is HOT.
Freezer nor Frigerator getting cold.
Read this post, it helped me when i had the same problem
http://www.fixya.com/support/t1444501-frige_freezer_not_getting_cold_fan
Posted on Jan 03, 2009
  • 3 Answers
Anytime you have your symptoms, you are so low on freon that there is no perceptable cooling. If you can put your hand on the compressor "high side" (discharge side and also the smaller refrigerant tube exiting the hermetic compressor) while the compressor has been running a few minutes and it is not hot or very warm to the touch, you are low or out of freon. Refrigerators do not normally utilize expansion valves but have capillary tubes at the inlet to the evaporator coil, which would normally eliminate possible trouble. If your refrigerator does have an expansion valve ahead of the evaporator coil, it could be the culprit, if it "sticks" closed, preventing refrigerant from circulating.
Usually when a refrigerant circuit begins to loose freon, you first notice that "frost" may begin to form on the evaporator coil (refrigerator side). Look in at the rear inside panel of the refrigerator to see if there is a layer or buildup of ice / frost on that panel. That is a sure sign that you are low (but not out of freon).
Usually, there is already a freon service valve for adding refrigerant.
If you are mechanically inclined, I could give you more detailed instructions to "charge" your refrigerator. You must have a freon can tap (for the appropriate refrigerant), a refrigerant hose that mates with the "access valve" on the compressor and to the freon can tap / valve.
Posted on Jan 02, 2009
Why has my freezer stopped cooling ?
The freezer does not get cold the evaporator fan motor might have stopped working.
http://thesisreviewadvisor.com
Jan 08, 2015 | Refrigerators
GE refrigerator profile arctica Not cooling frige or freezer PTS25LBMARBB
well if the compressor dont have power so how could it work or cool?
Jan 16, 2008 | Refrigerators
Fridge isn't staying cold, the freezer works OK.
if your freezer is working fine and you hear your compressor running you could have a frozen drain tube or more than likely the evaperator motor fan has failed.this is the fan that circulates the cold air from freezer throughout frigerator.what kind of unit is it?side by side or top mount freezer or what?let me know
Dec 25, 2012 | Refrigerators
My compressor stoped working and it got hot and
If the fan was the problem and the compressor is now running , it should start getting cold.
Oct 16, 2009 | Amana ARB2217C Bottom Freezer Refrigerator
Kenmore Top Freezer not getting cold (freezer or refrigerator), fan works. Occasional click down by compressor? Any advice appreciated. Trying to fix cheap as this is an 8 year old 2nd frigerator we keep...
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and refregirator are both down
sounds like the defrost timer is malfunctining and leaving on the heaters that melt the ice. or it may have just came out of defrost. take and feel the lines where they go into the compressor in the back. watch out for the fan blade when doing this. one should be cold and one hot. if not then the compressor may not have enought refrigerant in it. anothe thjing to check is the coils are they clean. the oines that are underneath are what i'm talking about. if they are not oyou will have toi clean them. good luc and let me know if you need more advice.
Jan 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigerator is freezing.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Sep 12, 2007 | Daewoo FR-147RV
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
177 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
