Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Cracked projectiom lens
How do I fix it?
  • 185 Answers
Are you sure it's a cracked lens? if so observe the delta number and buy a replacement.
Posted on Jan 02, 2009
I have hitiatchi 55"rear projectiom that has all blue i can see imiages but all dark and blue what the fix on this . thank you anyobe who can help model51f510
Absence of green color. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Televison & Video
Cracked lens on epson 3020 projector can it be fixed ? How much$?
Lens for epson 3020,unit price :USD420
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Mar 03, 2014 | Office Equipment & Supplies
Hi, i HAVE A 2003 HONDA ACCORD COUPE. MY TOUCH SCREEN WAS SAYING DVD DISK ERROR SO I UNPLUGGED THE BATTERY AND NOW IT IS SAYING CHECK DISK. PLEASE HELP HOW DO I GET MY TOUCH SCREEN BACK UP.
Dvd disk error and check disk error both are same error.The name is different.In both cases the lens in the dvd unit needs to be checked.The lens is either moved from its position or getting blocked by any dust or any dirty stuff got stuck up on the thin lens glass internally.
In some cases the lens is cracked so the lens assembly needs replacement.But first try cleaning the lens with a dry tissue.You can also try blowing air from air blower first.Blow air in the unit where the disk is inserted/placed.Then check.If still same then the unit needs to be removed out to disassemble to clean the lens manually and also this will help to know if lens is cracked or faulty.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 11, 2010 | Car Audio & Video
Lens got dropped and the out glass cracked. Lens
Hi, there.
I assume you mean the 77mm FILTER that was screwed on the lens.
Apr 25, 2010 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
My lens is cracked on my flip cam, how do i fix it?
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Apr 15, 2010 | Pure Digital Flip Video Ultra Camcorder
Exterior Lens (cover?)has cracked. Is
Hi
Did you find a solution? My DMC FT1 has also just cracked it exterior lens cover. Ive'removed it an dit takes fine pics still now, but it ain't gonna be waterproof at the moment!
Feb 11, 2010 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
My son dropped our flip camcorder and the lens is cracked
[eBay] has replacement lens for the Flip Video. $15.99 free shipping. Also comes with protective lens covers.
Jan 03, 2010 | Pure Digital Flip Video Ultra Camcorder
The lens cracked. The camera still works but the picture shows cracks. Is it possible to repair it?
The same thing happened to mine. Customer support was useless, telling me I voided my (expired) warranty by breaking it, and that it is not a replaceable part.
Here's the fix that worked for me:
If you look closely at the metal bezel around the lens, you will see a seam between two metallic parts, near the front surface of the lens.Take a knife and gently work it around that seam until you separate the two pieces. They are held together with doublestick tape, so they come apart easily. That will expose the lens which is actually not a lens at all, it's a window; a flat glass disk. Take the tip of a pointy knife and gently pry the glass piece(s) off. Again, this is held on with double-stick tape so it will come off easily. If you can find a glass disc that is the same diameter and thickness, you can place that in. The disc is a 20mm diameter by 1mm thick. You can probably order a replacement watch crystal from somewhere like this place:
http://www.esslinger.com/roundmineralglasscrystalx1mmthick.aspx
They cost less than a dollar (not including minimum orders, shipping, etc), and they are probably more scratch/crack resistant.
If you don't want to bother replacing it, your camera is still fixed, just a bit uglier and vulnerable to dust. The front lens has no optical significance, it's just a dust cover and/or a design element.
The metallic bit you took off is little more than a piece of tin foil.
Had they used a more substantial part that could divert shock instead of directly transferring it to the glass, there would be far fewer cracked lenses out there. But that would probably hurt their "go buy a new one" repair policy.
Jul 12, 2009 | Pure Digital Flip Video Ultra Camcorder
Lens extends after power, then buzzes, then goes back in and shuts off. It was working not too long ago. And I haven't dropped it. But I just tried to use it and it doesn't want to work. The battery seems...
Go to this website: camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera
I couldn't fix my Pentax Optio S10, but this is the best web site I found to address the problem we both have with lens extending, buzzing, then shutting off. I took my camera apart, and found that my lens was cracked around the edges.
Nov 01, 2007 | Pentax Optio S7 Digital Camera
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
