Question about Toshiba Satellite A65-S126 Notebook
How to find net for wireless - Toshiba Satellite A65-S126 Notebook
  • George Crooner May 11, 2010
    Well you can get net for wireles wherever it is available out there, bottom line is your laptop will detect it, will connect if possible and then you´ll be asked for a password, unless it is an open net for public access available in certain places like cafes, restaurants and so forth, in certain countries...
I have a desktop intel d850mv i tried to use the wireless internet like alfa wireless but not working at all. it works only on telephone internet. what seems the problem?
Hello
do you have a wireless network set up does the PC find the wireless net-work also you can try using a Cell phone to find the wireless net-work. then if you are able to get the cell phone on the wireless net-work that means you should be able to get the PC on it also.
please rate
Jan 23, 2011 | Zerus Intel Desktop Board D850MV...
I can connect to the net thru the dsl modem, I can connect to the wireless router but I can't connect to the net wirelessly thru the router-dsl modem?
check your routers setting for the wireless connection check if the wireless of your router is turned on to provide wireless signals... check if the SSID of your router if it is set as well to be detected or if it is hidden, make sure it is set to be seen by devices for your laptop to detect the router wireless.
Oct 08, 2010 | Linksys Wireless-G Broadband Router
Cant connect to wireless net
may be your wireless connection is not active...
Feb 03, 2010 | Hannspree SN10E11BUF Notebook
Intel set pro is showing wireless physical adapter not installed
since i got the motherboard changed, the wireless adapter had changed and i didn't realise, i was trying to download the wrong drivers, i finally got the right driver for the dell wireless wlan mini card and now everythings working fine.
Aug 27, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Hi! im conencted wirelessly but i cannot access some websites
well if you can browse the net with .net and not .com
you should check with your service provider, they must have blocked the .com domains.
Jan 27, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless net
Can you connect to the router?
please do the following
Start/run/cmd<enter>
type "Ipconfig <enter>"
copy the results in to a message window so I may see it
Nov 04, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Home wireless network
A wireless router of course :-)
Az.
Sep 17, 2008 | Dell Inspiron 6400 Notebook
How to find the router ip address
Greetings...
You need to have a computer with a wired connection to the router to make this change... this is a Toshiba PCX5000?
open a browser and type in 192.168.100.1
it will ask for a password or make you setup a password, make sure you write password down... if it asks for a password and you do not know it, you will have to push the reset button and reset the router to factory specs and then add a password...
after accessing the router... in the left hand side bar click on wireless...
goto the wireless settings...
Wireless Net Name entry box - Also called the ESSID, the Wireless Net Name is the unique name
shared by all devices on the wireless network. All wireless devices on the network MUST use the
same Wireless Net Name to communicate with each other and the access point. The name can be
up to 32 characters long. By default, the PCX5000 uses “PCX5000” as the Wireless Net Name.
SAVE the settings and exit the router...
Manual, drivers and other information on the router are here
Have a great day...
Ed
May 28, 2008 | Toshiba Computers & Internet
Wireless camera setup
hmm...serve bacon with the scrambled Nets?..he..he
did you know that 2.4 Gig is the same frequency as your wireless net? get em away from each other. May need to shield one(yes..copper plates)..
try distance first though
check your computers warranty here 4 FREE
Mar 16, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar http://192.168.2.1 u can see the belkin login screen and follow this link
http://www.gorge.net/help/wizard/belkin/f5d7230-4_pppoe.htm
rate me solved if its helps
Nov 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Toshiba Satellite A65-S126 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
