Question about Panasonic SC-PM19 CD Shelf System
No sign of power
Today I pressed the remote to turn the system on. Then I pressed "1" on the remote pad thinking that was the way to access the CD in the first tray. There are two or three discs in the tray stack, and I probably pressed that pesky "1" before it cycled to its starting point. Big oops! Since that time, the stereo seems to be basically dead! When it's plugged in, there's not even a red light on for "AC in." I left it unplugged for several hours, then plugged it in again. The "AC in" light came on briefly, then the system turned itself off. What to do? Is this the power amp module or a resistor gone potty? Or is it something I did with my finger twitching on the remote? Is there any way to reset the system? This Panasonic SC-PM19 CD stereo system is no longer under warranty.
SOURCE: Panasonic 5 DVD/CD Stereo System with MP3 SC-PM91D - the remote stopped working.
I had the same problem thanks so much for solving this for me to.
Amy
Posted on Oct 26, 2008
futurework
  • 70 Answers
SOURCE: my panasonic cd stereo system SC-AK600 keeps
sounds like the laser is no longer working. Call partstore at www.partstore.com and let them know what model number you have and that you are looking for a replacement laser for the unit. Replacement is for the mechanically inclined or a technician. The part is static sensitive so I recommend taking the unit to a repair center.
Posted on May 05, 2010
walesarumi
  • 6993 Answers
SOURCE: My school room has a
This seems to me like a power problem. the system might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Jan 01, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a Panasonic CD
F61 is generally a 'shorted-speaker' or 'microprocessor' problem.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 30, 2011
  • 910 Answers
SOURCE: Panasonic SC-HC3 micro system .
The least you should do is with the unit unplugged, remove the rear cover and check for an internal fuse. It should be somewhere near where the mains cable plugs in.
Posted on Jun 28, 2011
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
Kenmore microwave model 721.80039700. microwave starts beeping on its own. Display screen displays 1 then 2 then 3 then 4 over a short period of time. key pad hs stopped working. cannot start of turn...
SOUNDS LIKE A BAD TOUCH PAD THINKING YOUR PRESSING EITHER THE 1-3 PADS, IT WONT TAKE OTHER PROGRAMING CAUSE IT THINKS YOUR PRESSING THE 1-3 PADS. REPLACE TOUCH PAD
Feb 26, 2018 | Microwave Ovens
Where is a free download for User Manual for T40 IBM Think Pad?
A User's Guide is not available in PDF file form, or hard copy.
ThinkPad's are preloaded with the Access Help application, which contains information similar to that which would be included in a User's Guide.
1) System locations, views, and connections.
2) How to setup, configure, and customize your settings including;
A) Power Management
B) Networking
C) Wireless
D) Display Settings
3) Enable system protection including;
A) Virus Protection
B) Recovery Techniques
C) Security Software
D) General Maintenance
You can access this application by pressing the appropriate button on the top left of your Keyboard;
1) ThinkVantage button
2) Blue Access Help button
3) ThinkPad button
http://support.lenovo.com/en_US/guides-and-manuals/detail.page?DocID=UM002042
Anything specific I might be able to help with? Post in a Comment.
Regards,
joecoolvette
Feb 25, 2012 | IBM ThinkPad Computers & Internet
912-the computer has been removed.the machine cover have been removed since
Make sure you close the case cover first before performing the steps below
1. Go to BIOS by pressing F10
2. Select hardware monitor setup and enable the reset case open status ANOTHER SOLUTION IS
1.turn on ur PC.
2. press F10
3. wait 10 sec.
4. press "right arrow" 1 time
5. press "enter"
6 press the "+" sign on ur numeric pad
7. press F10
8. press "enter"
May 22, 2011 | HP Compaq Presario SR2011WM PC Desktop
Hi, my old remote key pad used to lock itself so if I bumped it in my pocket it wouldnt start. I bought a new 2 way recently but the key pad stays unlocked. How do I get it lock?
Press and hold the "f" for 8 seconds to access the remote programming features. The remote will emit one long beep and the LEDs will illuminate. Press the unlock button to access the remote programming features. Two transmit LEDs will flashes and two beeps indicate the remote programming features are accessed. Press the lock button on the remote( LED on indicates auto locking on, LED off indicates auto locking off). Press and release "f" button to exit programming.
Apr 12, 2011 | 872 Responder LE keyless entry security...
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Don't Know how to program Dish satelite or tv with my remote.
to program the dish remote to the receiver you need to access system info, if there is no system info button on the receiver turn the receiver off and press the up arrow on the front panel, then press record on the remote, to change the remote address hold down sat until all buttons illuminate, enter number between 1-15, press pound sign, then press record
to address a remote to the tvyou need the remote code for that brand or you can do a power scan
Jul 20, 2008 | RCA DISH Network(r) 311 Satellite System
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Echostar IR remote (Dish)
to set remote to tv
3)press pound sign
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Panasonic SC-PM19 CD Shelf System Logo
21 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
