Question about Regal Ware K813BK La Machine Food Processor
Gear breaks Where to find the small plastic gear that usually breaks in the Regal LaMacine I food processor motor?
3 Suggested Answers
  • 55 Answers
SOURCE: My Hamilton Beach Food processor model # 702-1 has
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Posted on Oct 14, 2009
dcramer531
  • 1654 Answers
SOURCE: regal food processor/ lamachine1 model
The motor has a plastic gear that breaks easy. It is hard to find, but the solution is to replace the plastic gear. you can find most of the parts for this machine at http://abtecparts.com/Moulinex_Regalware_La_Machine_I.htm
    Dealing with a worn or broken belt
  1. 1
    Unscrew the machine's base, using a screwdriver. You may need to pry off the rubber feet to access some of the screws.
  2. 2repair-food-processor-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a00/3d/qh/repair-food-processor-1.2-800X800.jpg'); });
    Inspect the drive belt (see A). If it is slack, loosen the screws holding the motor assembly (see B), and follow step 4 to increase the belt's tension. If the belt is broken, get a replacement from an appliance store or the manufacturer.
  3. 3
    Install the new belt. Loosen the screws holding the motor assembly, and shift the drive gear toward the reduction gear so you can slip the belt over each gear.
  4. 4
    Shift the drive gear away from the reduction gear to increase the belt's tension, then tighten the motor-assembly screws.
  5. Dealing with a worn drive gear
  6. 1
    Inspect the drive gear. If the teeth are worn, you need to replace it. Remove the drive belt as described above to access the gear.
  7. 2
    Remove the gear, using an Allen (hex) wrench to loosen the setscrew in the side. Then buy a replacement from an appliance store or the manufacturer.
  8. 3
    Slide the new gear onto the drive shaft, and align it so the center is parallel to the center of the reduction gear. Tighten the setscrew with the Allen (hex) wrench.
  9. 4
    Replace the belt, and increase the tension as directed in step 4, above.
  10. 5
    Reinstall the base and any rubber feet you removed.
Posted on Dec 26, 2010
How do I remove the plastic gear from magic bullet
GO TO BLENDERGEARS.COM
THEY HAVE ALL THE MAGIC BULLET GEARS THERE. I RECENTLY FIXED MINE.
Oct 22, 2011 | As Seen On TV Magic Bullet Food Processor
The rubber gear attachments with the grinding glass jar is somewhat burned because if i put the vegetable to grind it wont but if i will start the machine empty without any vegetables it works.Can you...
Are you sure the rubber gear is burned? have you turn the plastic lock on the bottom, so everything is thight? have you checked that the plastic O-ring is well placed?
Mar 12, 2011 | Braun K 3000 Multisystem Food Processor
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
Oct 14, 2009 | Food Processors
Plastic gear broke
So, rather than pay for an entire new motor and wait for two weeks forthem to get it to me, I just made a new gear/broken thing. I crazyglued the old piece back together again and used it to make a plastermold...like the way people do with their kid's hands. Then I filledthe mold with JB Weld and let it dry. After that, I drilled a hole inthe new JB weld gear so that it would fit over the metal part in thebullet(that actually spins).
Glued it on (with more jb weld) and the thing has been making my smoothies and grinding my coffee with no more issues.
Sounds complicated, but it wasn't too bad. Funny thing is, the newpiece is probably heaps stronger than the cheap plastic thing thatbroke in the first place.
Do it yourself, or e-mail me: sanfransimo@gmail.com
I'm tired of made-to-break products and could make anyone else one of these things for around 10 bucks!
Feb 14, 2009 | As Seen On TV Magic Bullet Food Processor
Is it possible to obtain a replacement for the internal gear
www.saladshooter.com is where to go for parts for you salad shooter!
Please rate this free response
THANK YOU!
Jan 17, 2009 | Presto SaladShooter Plus Food Processor
Drive gear link on top of Cuisinart motor broken
I bought two for $10 plus shipping from buyitnowstore.com. The remaining metal piece from the plastic "clutch" is hard to remove and I have not figured that out yet.
Jan 11, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
Stopped working
Dec 22, 2007 | Regal Ware K813BK La Machine Food...
Food Processors Logo
Top Regal Ware Food Processors Experts
eyecam
Are you a Regal Ware Food Processor Expert? Answer questions, earn points and help others
