Question about Garden
Can not remove chain easily model ms1635 - Garden
  • rjbdevel341 Jan 03, 2009
    mccolough ms1635  --- cant find owners manual
  • jcsaws May 11, 2010
    what brand and model is it. did you get owners manual??
  • 231 Answers
There is a tension adjustment screw. Look at section C of this sample manual for McCulloch. It's not the same model, but it should be close enough. =>
Posted on Jan 03, 2009
H0w do I repair my McCullock 35cc Chain saw
The gas filter is going to be dangling inside the fuel tank on the end of the fuel pick-up line. Hook it with a short piece of wire and slip it to the edge of the fuel opening. Be careful as you can easily destroy the actual fuel line in the process. It will NOT stretch as far as you would like for access to the filter. The filter is connected to the fuel line with a plastic barb fitting that inserts inside the line. Remove and reinstall the new replacement.
The chain and bar are removed by first loosening the nuts on the side of the case. Next, look between the two nuts for a screwdriver adjustment....if not there, look from the front of the saw down alongside the inside of the guide bar and up against the case should be a screwdriver slot. Turn it COUNTER clockwise to loosen the chain to a drooping loop. Remove the two bar nuts and side case and the bar and chain will easily slip off.
Jan 27, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to know a vehicle has timing belt or timing chain? this website is not working. please advise. Thanks a lot
Most car timing covers are either metal or plastic. the timing chains are usually in a metal sealed cover due to oil being used to lubricate the chain and gear assemblies and timing belts are usually in a removable plastic housing with some sort of access cover to inspect the belt, usually it is a two piece cover where as a timing chain is in a one piece cover. know-vehicle-timing-belt-or-timing-c3hyvbb5dw5lz1xfja5a3wpz-4-0.jpg
Aug 13, 2013 | Vehicle Parts & Accessories
What is the proper fuel mix for a mcculloch ms1635 chain saw?
between 32:1 and 40:1 - Manufacturer recommends 40:1 Ratio - EXAMPLE: "Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio."
Sep 02, 2010 | McCulloch Garden
Need to know how to take clutch off stihl chain saw ms250
take the bar cover off, remove the bar and chain. there will be a lock key that u can easily remove with a flat head screwdriver, after u get it off all pices should slide out easily, just rember how to put it back and make sure not to mess up the oiler needle
Aug 05, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Does not idle
A link to a MCC 1635 OM follows:
From page 11
In some cases due to operating conditions (altitude, temperature
etc.) your chain saw may need a slight adjustment
to the idle speed.
After warm up - See the User's Manual section 5-2, step 7
- If unit does not Idle after restarting 2 times, follow these
steps to adjust idle.
1. Idle adjustment access (G). (Figure 5-2H)
2. Using a Phillips or slotted screwdriver - turn screw 1/4
to 1/2 turn clockwise (to the right). Unit should then
idle properly. (Figure 5-2H)
NOTE: If chain turns while idling - turn screw back to the
left until chain stops and unit continues to idle.
Anything beyond this the OM recommends to a authorized dealer. Not bad advice, I suggest a local Stihl dealer.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Thank You for using FixYa.
Jul 28, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need help finding chain tension screw/adjustment on mcculloch 16'' chain saw or a good link to a free manual for this model ms1635.
You can find an OM here:
Jun 20, 2010 | Garden
Changing chains.............chain brake on or off
Off, else you cannot easily remove the clutch cover; and you cannot reinstall it if tripped. Wear gloves ensure you can rotate the chain before removal.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Apr 20, 2010 | Husqvarna 450 e-series 18" Chain Saw
I need a mamual for McCuloch chain saw CS 38EM
A more common model number is MS1838AV. Your IPL follows:
Chainsaws 32cc-35cc-38cc Anti-Vibe
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered (I did not get any hits). HTH
Feb 17, 2010 | McCulloch Garden
Garden Logo
196 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
