Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rinnai 4004 flashing 99, what is the problem - Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
  • 1,420 Answers
Pressure switch or bad communication with sparker board
Posted on Jan 05, 2009
Rinnai ex 38 flashing code 99. I took the vent apart and there is no blockage. Unit has only been installed one month.
If it is only one month old doesn't do anything but call for warranty serving. ANY attempt to repair this will void the warranty.
Jan 10, 2017 | Rinnai Heating & Cooling
Rinnai code 99
i am not an expert. this is how i fixed my rinnai code 99. my rinnai 100 4f would run for few seconds then the red light would continue to flash. code 99 would come up.i took the unit out of service. i notice that the fresh air hose had two very small hoses located on it's elbow had been switched around when i took it to be serviced. the unit worked well. how ever. i changed my mind when i realized the service was not need. anyway the two small hoses on the elbow one office is larger than the other and they must be put on the correct one,i switched them around the unit flamed up. and now i have sweet heat again.no code 99.
Dec 17, 2016 | Rinnai Heating & Cooling
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Code 99 flash after 5 min and then turn off
Flue block or venting disconnected. You could be getting cross contamination or the flue termination could be iced up. Check it out closely. There is also a recall from Rinnai for a retrofit kit. Contact your gas service provider with the serial number of the unit and they will tell you if yours is under the recall.
Feb 16, 2010 | Rinnai RHFE-556WTA Direct Vent Heater NG...
The heater keeps shutting off , getting a 99 code
Terry,
Remove the flex hose from the flue pipe inside the house. Try to start the stove. If it runs there is a problem with the flue. If it's been very cold look closely at the pipe around the exhaust pipe. That is the air side. There could be frost built up inside the air pipe. If so it will shut off the gas and you can't run the stove.
Tom Hawkins
hawkins111@gci.net
Jan 31, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Flashing code 99
Error code 99 has to do with the flue pipe being blocked. You could have ice or frost on the exhaust or air intake. This reduces the combustion air to the unit which in turn stops the fuel flow.
Tom Hawkins
hawkins111@gci.net
Dec 21, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
67 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
